Sprocket choice
Results 1 to 2 of 2
Like Tree4Likes
  • 3 Post By Maxpower
  • 1 Post By Gulfrider
Thread: Sprocket choice
    Feb 2017
    Waretown NJ
    544
    Sprocket choice
    I first bought a 45t rear sprocket.I think JT was the brand. However for some reason it was machined thinner at the holes. It created an issue because I had to stack a few washers on each bolt because the threads on the stopped short .
    My 42t rear is a Sunstar and was much better.It was the same thickness as stock and was able to ditch the washer stacks. So be careful which sprocket you buy when it's time.
    Peterb, lugnut and plumbstraight like this.
    87 TW
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    I use a JT set and yep, that rear is just thinner at that area. I just put few washers on the back side. Works fine and was cheaper. I use a JT x-ring chain as well.
    plumbstraight likes this.
    2005 TW200
    2007 Sportster 1200
  1. I'm sorry, but you've left me no choice...........
    By r80rt in forum General Discussion
    Last Post: 03-09-2014, 04:28 PM
  2. Seat concepts seat material choice
    By Mystic Explorer in forum Performance and Customization
    Last Post: 01-30-2014, 08:36 AM
  3. Tough Choice - Keep the TW or ????
    By Tracker in forum General Discussion
    Last Post: 11-10-2013, 07:42 PM
  4. best rear tire choice?
    By mack in forum Performance and Customization
    Last Post: 11-08-2012, 10:15 AM
  5. 1st Choice for a 2nd Bike?
    By DonBenito in forum General Discussion
    Last Post: 08-05-2012, 08:55 AM
