Skinny Tire Dual Sport Verses TW 200
Results 1 to 10 of 16
Like Tree28Likes
Thread: Skinny Tire Dual Sport Verses TW 200
    Member Mystic Explorer's Avatar
    Aug 2013
    51
    My 45 year old son and I rode TW 200's for years until we moved to an area not good for off road riding. Now that we are back in Oregon we want to start riding again. He thinks he wants something like an XT250 with skinny tires. I am in my 70's and want stability.
    COuld anyone who has ridden both types of bikes share what the ride difference is.
    Thanks for responding
    Junior Member philo's Avatar
    Nov 2018
    22
    TW Pros:
    Lower seat height
    Wider tires
    Price
    XT250 Pros:
    Everything else
    Peterb and jonnyquest like this.
    Aug 2013
    51
    What is the ride and handling difference between fat and skinny tires
    Frosty Hollow
    13,024
    Quote Originally Posted by Mystic Explorer View Post
    I have and ride a TW and XT200 (Skinny tires). In my case I can't really tell enough of a difference with either in comparison to tires to even make mention. I think the XT wiggles just a tad more on all off-road surfaces but when you apply power but it has good traction and you don't even notice. I do feel more confident going over rocks with the TW but I go the same places with the XT so don't know if it's just in my head. Both do about the same in sand. On gravel roads I wander around the same on both. If the TW's wider tires are suppose to be an advantage I can't figure it out!
    What I do notice between the two is the XT200 is about 50 lbs. lighter and a bit easier to handle on tight trails. I think the XT250 weighs closer to the TW than my XT200 does. My XT is only slightly taller than the TW but it's not a XT250. I do like the TW's lower seat height most of the time.
    The XT250 will have more power if that's what your 45 y.o. son is looking for.
    Tweaker and ejfranz like this.
    Jun 2015
    Nova Scotia
    1,390
    Skinny tires dig into soft terrain deeper then fat tires. This is an advantage and disadvantage depending on speed and terrain. TW will slide more on loose terrain (like gravel) then a narrow tire, as a narrow tire cuts a line, the wider tire disperses it's weight over a larger area reducing traction. When a skinnier tire digs itself into a hole the TW is more likely to keep rolling.
    A skinnier tire can fit into smaller lines offroad and a TW will need to slip you side to side at times when the tire is too wide for the line you chose to ride. The round stock tire is more forgiving for this then a tire with more bite on the corner treads.
    TWs large tires give the illusion of greater traction but I suspect it is the low gearing that is less likely to break traction by roosting dirt behind it like other faster bikes. The gearing is easier to control and better suited to lower speeds then most bikes.
    TW tires are less likely to get pinch flats and offer a smooth ride that leaves less of a "foot print" then skinnier tires.
    If you're already familiar with a TW then it's going to be more comfortable and predictable then any other option.
    These bikes appeal mostly to an older demographic for good reasons....easy to ride, fun, and not too fast.
    18,681
    Wide tires sure seem to help me in sand, silt, mud and snow. A few of my riding buddies have XT 225, WR250 & KLX 250 bikes. While their 6 speeds can leave me behind on pavement and faster fire roads I can occasionally traverse sections that cause them grief. But then again their vastly superior suspensions allow them to go much faster and/or safer on medium rough terrain.
    While it has been awhile since I rode a skinny tire bike in silt and blow sand I say based on back-to-back experiences that a Duro ATV tire equipped TW is much more stable than a stock TW's rear TrailWing tire.
    Trail Woman likes this.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,482
    For me the place where I find the TW shines compared to almost anything with a 21" front wheel is on twisty paved roads. In the bush my buddies Super Sherpa does everything as well as my TW.
    Apr 2014
    Dryden NY
    6,336
    The BIGGEST difference is in ownership. Nobody follows a skinny tire dirt bike into a gas station just to ask what it is and how much it costs! I NEVER get as much attention on my 500X as I do my round bottom girl.
    Tom
    Fred, JerseyJeeper and Peterb like this.
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    Depends on the terrain.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Jan 2017
    Southern Nevada
    1,077
    Good synopsis by Trail Woman.
    I have owned both.
    Both were new.
    Had both for about the same length of time and miles.
    Dropped the XT 250 3 times.
    Dropped the TW200 zero times although I pushed my limit on one extended solo ride.
    XT250 has a longer range, better suspension, ~10 MPH faster and can clear an intersection in first gear, but I would recommend the TW200 for trail riding.
    I am almost 72, owned 17 M/C and rode for 55 years.
    My most recent bike did 0-60 in 3.3 seconds.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  1. TW 200 Verses 4x4 Back Country Adventuring
    By RikR in forum General Discussion
    Last Post: 08-27-2017, 09:58 AM
  2. Battery verses kick starter
    By jaxster in forum Technical Help
    Last Post: 03-01-2016, 03:12 PM
  3. Yamaha TW200 2002 TW 200 dual sport - $2195
    By socalbubba in forum TW200 Classifieds
    Last Post: 07-29-2014, 11:59 AM
  4. WTT my sport bike for your dual sport
    By Alien mastermind in forum TW200 Classifieds
    Last Post: 03-12-2014, 12:37 PM
  5. BUCKET LIST- Yamaha TW verses Harley Davidson
    By Mystic Explorer in forum General Discussion
    Last Post: 11-19-2013, 02:47 PM
