Inflator pump choice
Results 1 to 10 of 17
Like Tree13Likes
Thread: Inflator pump choice
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    123
    There seem to be a wide variety of those inflators, ranging from $25 for the Slime (seems highly rated) to the high dollar Best Rest Cycle Pump for $130 or so. What do you gentlemen/ladies think or prefer? Thank you for your time.
    Jul 2012
    Wet-ern Washington
    1,409
    I dislike the Slime type cheap-o pumps because they have a crap duty cycle. I like the Moto Pump, as seen in the video. They also now make a smaller version that appears to be good.
    From the YouTube description...
    2017·Here is my quick review of the Motopumps Mini Pro tire inflator designed and built for motorcycles by a rider.
    Motopumps Mini Pro specs:
    Pump Dimensions: 2″ x 4.75″ x 5.75″
    Weight: 18oz
    Main power cord with SAE plug 6.5′ reach
    Combo Cigarette / BMW plug to SAE cord 3.5″ reach for a total of 10′
    Durable Polyurethane 3′ Coiled Air Hose with Zero Loss Connector stores onboard.
    50 PSI capacity, .5 cfm, integrated air cooling for long run times with no heat buildup.
    Source: www.motopumps.com
    ADV rider forum thread: http://advrider.com/index.php?threads...
    On Amazon: http://amzn.to/2AyejmW
    This is not sponsored, but a review of from an actual user that purchased this product.
    Thanks for watching! If you like what what you see, please thumbs up and subscribe to let YouTube know. Thanks!
    assquatch20 likes this.
    - Leisure Time Larry -
    Senior Member RaZed1's Avatar
    Oct 2015
    285
    I have a Stop -n- Go tire repair kit (tubeless) in my Valkyrie. It has one of the cheapo mini air pumps that plugs into the battery tender connector. It is pretty chintzy and yes does have a limited duty cycle (believe it says 10 minutes constant operation max), but it takes about 5 minutes to air up one tire from flat, so it's not really a big deal. It's really for emergency use only, not something you'll be using daily in your shop so to me it gets a pass. It is very compact- maybe the size of two packs of cigs? For bikes with tubed tires like the TW I always just throw a little Slime in the tubes. At least if I get a nail or something it'll slow the leak sufficiently to ride it home and not get stuck on the side of the road.
    The little CO2 can powered inflators are great for being light and compact, but they're single use.
    They also make hoses that screw in place of the spark plug, and you can use engine compression to inflate the tire. They used to be a lot more common, now the compact 12v pumps and CO2 puffers seem to have largely replaced them.
    Aug 2018
    San Diego, CA
    123
    Thank both gentlemen.
    Senior Member NVcowboy's Avatar
    Jul 2018
    Spring Creek, NV
    591
    Well if it's for your tires I certainly do not recommend the "Austin Powers" brand.
    If you have to shoot, shoot. Don't talk. - Tuco Juan Ramierez aka "The Rat"
    There's 2 kinds of people in this world, those with guns, and those who dig. You dig. - The Man with No Name
    2018 TW200 - LCpl. Rex T. Dubber
    2010 Savage S40 650
    18,719
    Quote Originally Posted by Cerberus View Post
    I like the cheap ones since I can leave it untended on the bike for worry free hiking. If someone takes it no big deal. If I had the expensive model I would either have to worry or carry it; both options detracting from the primary goal of having fun adventures on the TW. Smart operation eliminates concern about overheating and a possible short duty cycle since I only use it on a motorcycle. Just a few minutes does the job.
    Sent from my moto g(6) using Tapatalk
    Ken and DougDotyTW200 like this.
    Jan 2017
    Southern Nevada
    1,077
    I have a German made super compact footpump in each vehicle. Lightweight and no battery needed. The one in the truck is a backup for a heavy duty (clamp direct to battery) electric.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Sep 2014
    Mamaroneck, NY
    2,177
    I have couple of CyclePumps, a Slime pump, and a Milwaukee 12V battery powered inflator (in the truck). The Cyclepumps are great. Have had no issues with any of them. The Slime pump has been around since 2007 or so, and works very well.
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    763
    I have 2 of the slime kits - comes with slime and pump/ One on my ATV and one on the Dub. The one on the ATV has seen a lot of use on friends and mine over the years and has held up very well - not expensive but must be well designed.
    Fred likes this.
    Jun 2016
    New Rochelle, New York
    1,766
    Cyclepump. One of the more expensive ones at $100.00 but I got it as a gift and it came with a separate pressure gauge as well. about 10 years old and still ticking.
    I think going from the cheaper to the more speedy units folks have to remember how small the compressor is in all and how hard it has to work. It you leave it on too long you will blow-it out/overheat it. For my sidecar rig I also keep a bicycle foot pump in the trunk.
    1995 BMW K75 (Elec Start)
  1. Looking for Portable Tire Pump
    By TundraManDan in forum General Discussion
    Last Post: 06-15-2012, 07:48 PM
  2. oil pump gasket??
    By operose in forum Technical Help
    Last Post: 04-09-2012, 09:26 PM
  3. Gas/Pump Advice
    By drs6222 in forum General Discussion
    Last Post: 04-06-2012, 07:19 PM
  4. Tire Pump; Air Pump; Air Compressor
    By retmotor in forum General Discussion
    Last Post: 12-29-2011, 06:17 PM
  5. Oil pump
    Last Post: 10-30-2011, 10:52 AM
