Electrical diagram for 1987 going to 1989 motor
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By GaryL
Thread: Electrical diagram for 1987 going to 1989 motor
    Junior Member ldyfthsky's Avatar
    Jan 2019
    1
    My motor went out on my 1987 tw 200 and I bought a motor from a 1989 to replace it but the wiring is a little different. I cant seem to find good diagrams to explain how to get this all back together. Any help would be appreciated.
    After looking at this forum and went and looked things up and it turns out my bike is an 89 not 87. The motor is supposed to be an 89 but the wiring doesnt match up.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,925
    Quote Originally Posted by ldyfthsky View Post
    First things first. You need to determine what year your bike is and what wiring harness it does have. 1987 and 1989 are completely different harnesses. 1988 - 2000 all have the same wire harness but the 1987 is very different. Under the seat and on a white label on the harness you should find a part number. Go to Partzilla.com and pull up the schematics for 1987 and 1988 TWs and under electrical you can see the harness part numbers. An 89 bike and 89 motor should be a plug and play swap. Until you know the correct year of your bike and the harness it has and the year of the new motor there will be no help.
    Ken likes this.
    1987 Yamaha BW350 Big Wheel
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    375
    Hello,
    The main difference is the charging circuit.
    1987, it is a magnetic flywheel
    1988, he is an alternator
    If it is an alternator assembly you can install that of a TW125.
    Alternator and rotor housing
    Mar 2017
    Yuba City, CA
    376
    Also (I believe), you can take the side cover and flywheel from your old engine, and install them on your new engine.
    That way, you'll keep the same charging system, and everything should plug back together the way it was before.
    Jun 2013
    Forestburgh, NY
    7,925
    The harness is the key. If it is an 87 with an 87 harness and you have an 88 or 89 engine then you will be missing some internal wires in the harness and others will be going to different places in the connectors if they even will plug up. 1987 has a one year only electrical system and harness and 1988-2000 have completely different harnesses.
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    210
    Anyone have a wiring diagram for an '88 to '00?
    1988 Suzuki Savage
    1987 Yamaha TW200
  1. New Carburetor...1987 and 1989
    By aaronloffler in forum Technical Help
    Last Post: 10-25-2018, 03:35 PM
  2. TW200 1987. wiring diagram in color
    By Miro in forum Technical Help
    Last Post: 10-08-2018, 12:47 PM
  3. Replies: 0
    Last Post: 05-09-2017, 10:23 AM
  4. Replies: 1
    Last Post: 07-25-2013, 11:38 AM
  5. Cylinder Parts Diagram Inconsistency
    By RodneyReed in forum Technical Help
    Last Post: 05-11-2011, 08:56 AM
