Spare parts.
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By RockyTFS
Thread: Spare parts.
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    176
    Spare parts.
    I'm going to be ordering some stuff just to have on hand. Seals for brake, valve covers, oil filter and orings, probably a spark plug.
    What else do you keep on hand?
    Bike only has 3k on it but I like to be prepared.
    For instance I was doing an oil change when I noticed an o-ring was missing. It would have been nice to already have that seal on hand.
    2001 TW
    Pleasanton, CA
    5,634
    If you plan on doing any serious off-road riding you may want spare brake and clutch levers .
    Jun 2017
    Milwaukee, WI
    1,204
    If you ever have new tires and tubes installed, make sure you ask the tech to save your old tubes. Even if they need to be patched/repaired they can usually become spares. For those of us that don’t mount our own.
    Spare oil filter is a good idea. But if you have the metal mesh type it can be cleaned and reused.
    01 street 203/204
    96 hybrid Shinko 241/428
    89 restored SOLD
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,691
    Get some spare bulbs.
    Dec 2018
    Los Angeles
    176
    If you plan on doing any serious off-road riding you may want spare brake and clutch levers [IMG class=inlineimg]https://www.tw200forum.com/forum/images/smilies/biggrin.gif[/IMG].
    At some point I will. At first I didn't think it was a problem if you have guards but now I've seen a few videos of people breaking levers on moderate trails with guards.
    So far we have 2 dubs in our group. A set of levers would be a good idea. Thanks!
    2001 TW
    18,407
    ...or quality handguards, they tend to prevent broken brake and clutch levers.
    Motor oil, filter oil and chain lube are expendable maintenance items good to keep on hand.
    Hailey, ID
    3,265
    Quote Originally Posted by TW Newb View Post
    Bike only has 3k on it but I like to be prepared. ...
    I found that the valve cover O-rings last about 6,000 miles; the exhaust is the first to get compressed to the point of weeping. The little O-ring on the Allen bolt on the filter cover got mangled at 5,000 miles but the replacement lasted 10,000 or more. I do look at it every filter cleaning. I replaced the oil filter cover O-ring at about 10,000 miles. Brake seals? Do you mean the caliper piston seals? I never touched them in 16,000 miles. Spark plug? I put an Iridium plug in when new and it was still fine at 16,000 miles. I re-used the original oil filter for the same 16,000 miles and would think it would go to 30,000 miles.
    The only other spare part I bought was a replacement gear shift lever and I still haven't used it 7 years later. Of course, brush guards were the first thing I added and I've never bent a clutch or brake lever.
    Mel likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Dec 2018
    Los Angeles
    176
    Rocky I was referring to the brake master diaphragm. I need to flush the system and I would prefer to have one in case i find it has a knick in it or something.
    The oil filter bolt o-ring was completely missing. However I did reassemble it without it and have seen no leaks.
    I will eventually adjust the valves and for reasons above I'd like to have the seals handy.
    Thanks for giving me a timeline of sorts as to when they likely need replacing
    2001 TW
  1. Spare parts and tool kit
    By Warren914 in forum Technical Help
    Last Post: 06-12-2016, 05:44 PM
  2. Replies: 4
    Last Post: 09-30-2015, 04:01 PM
  3. Moab Spare Parts List
    By Mel in forum General Discussion
    Last Post: 03-18-2015, 01:43 PM
  4. Use for spare parts Art from Thailand
    By arrowsmith in forum Off-Topic
    Last Post: 03-26-2014, 12:05 PM
  5. Spare parts checklist for LD adventure ride?
    By ProAm99 in forum Trails, Off-road, and Adventure Riding
    Last Post: 12-22-2011, 03:58 PM
