Flat tire repair
Results 1 to 8 of 8
Like Tree4Likes
  • 2 Post By ejfranz
  • 1 Post By ejfranz
  • 1 Post By Fred
Thread: Flat tire repair
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    176
    Flat tire repair
    Didn't get much traction on facebook so...
    I need info regarding tubes but post your tubless info as well for others.
    What do you carry for flat repair?
    2001 TW
    Feb 2015
    Maple Ridge, BC, Canada
    1,507
    For the front, I carry tire irons, electric air compressor and the glueless bicycle patches. Tube has slime in it, but I now use ride-on in my other motorcycles. Rear is a Duro, so if it goes flat, I doubt I will notice and just ride it out and deal with it at home.
    Miaugi and Fred like this.
    Senior Member RaZed1's Avatar
    Oct 2015
    252
    Slime or Stan's in the tubes. If you're really going off the beaten path, can't really escape bringing tools, irons, and a spare tube. I consider some in-tube sealant sufficient for general puttering around. If I pick up a nail or something in the road it slows the leak down enough to make it home. Heavy duty tubes can help resist pinch flats if you're running low pressure off road but don't do anything for pointy road trash punctures, and the extra rotating mass in the tires is noticeable for pavement performance and handling.
    Some people here have experimented with sealing up the rims with silicone and a rim mount valve stem, and going tubeless. Supposedly this works pretty well but I have not done it myself.
    Feb 2015
    1,507
    As a side note to this thread.
    2 weekends ago I was at the DualSportBC Flat tire social and they had a demonstration on how to install a mousse and why we should use one.
    Well, not quite sold on it, as they have a limited life span, but would probably last longer in the front of the TW.
    They are the way to go if you do not want to deal with flats and they are stable up to 80 mph.
    Ken likes this.
    18,437
    I sealed spokes for a rear rim with an ATV tire since the ATV tire is essentially non-removable in the field. Being Tubeless rather than running a stock tube allows greater success with sealants like RideOn as well as permitting use of simple plugs for common punctures.
    Front tire is in the hands of fate out on the trail with only pre-installed RideOn in the tube and an on-board air compressor. I am prepared to limp home stopping to pump up as necessary.
    These strategies evolved from earlier acceptable lesser alternatives like CO2 cartridges and cans of aerosol FlatFix.
    There are some true heroes out there but rare is the TW rider who has successfully repaired a puncture on a tubed Trailwing rear tire trailside. Those who have succeeded have my respect and admiration.
    Ken likes this.
    Dec 2018
    Los Angeles
    176
    Hmm... I wonder if previous owner added any.
    Slime/ride on seems to be the popular route.
    2001 TW
    Feb 2015
    1,507
    Quote Originally Posted by TW Newb View Post
    If the tube has Slime in it you can find out by removing the valve core. Just don,t remove it when the stem is at the bottom of the wheel.
    Ride-on is more viscous and takes a long time to pool. I doubt it would show by taking the valve core out.
    Dec 2018
    Los Angeles
    176
    Quote Originally Posted by ejfranz View Post
    I'll shoot him a text later and just ask lol
    2001 TW
  1. Flat tire repair on the trail?
    By bad luck in forum General Discussion
    Last Post: 06-16-2018, 11:37 AM
  2. CO2 Flat tire repair
    By matttw200 in forum General Discussion
    Last Post: 06-27-2017, 04:58 PM
  3. Replies: 3
    Last Post: 06-23-2015, 07:51 AM
  4. Flat tire repair
    By LouisianaTdub in forum Technical Help
    Last Post: 07-12-2014, 09:57 AM
  5. Flat Tire-Repairing/Supporting Motorcycle
    By RB63 in forum General Discussion
    Last Post: 04-27-2011, 10:42 AM
