The snowball effect!
Results 1 to 10 of 19
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    Rode the black widow to shop to replace sticky fuel petcock and take front wheel off for shinko (goldenboy) front tire upgrade. Next thing I know I'm replacing bad front steering head bearings, changing front shocks fluid, and adding Powermadd 2" handlebar risers! Doesn't look like I'll be riding this weekend.
    Senior Member yz250f4ever's Avatar
    Dec 2012
    Southern, CA (SO CAL)
    315
    awesome! I love replacing stuff that needs to be done. Gives you a huge feeling of gratification. Or maybe thats just me? I just like working on bikes i guess
    ALEX-
    My Current Rides:
    DIRT:
    2013 yz450F (race bike)
    2011 Yz450F (practice bike)
    2008 Yz250F (full mod)
    2005 TTR125 (full mod Gf's bike)
    Street:
    2009 DRZ400SM (full mod)
    2009 qlink XF200 (sumo build)
    2007 SDG 140cc big bore (supermoto)
    Hidden Content Hidden Content Hidden Content
    Sep 2012
    Northwestern Oregon
    1,092
    That's pretty funny.
    On the subject of the sticky petcock: any idea what causes that, or if it is fixable? The petcock on my 2003 is getting hard to turn.
    Member Twowheeler's Avatar
    Jan 2013
    Jacksonville FL
    79
    Oh yeahhhhh
    Aug 2011
    2,126
    The local motorcycle shop told me to remove two front screws of petcock, take out cone and polish with that green 3m scotchbrite cleaning pad. I did that about 6 months ago and did seem better but then got really stiff again and not fun trying to switch to reserve with vehicle behind you on pavement. A new petcock was only $26 so easier to just replace on my old bike.
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    well, you have it torn down that far.... you might as well tear it down the rest of the way and powder coat the frame, replace all the bearings, seals, tires, tubes, and put new plastic on it!! Oh, wait, that was my crazy logic!! ha ha!
    I couldn't resist tearing mine down once I had it that far, you have more willpower than I do!!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    It's been a while but if I remember correctly you can simply remove the faceplate of the petcock and lubricate around the OUTSIDE of the part that turns. You dont want that stuff inside your petcock. The contact between that and the faceplate is what causes it to be hard to turn. On old petcocks it can be a deteriorated inner gasket, but it will be leaking when off if that is it.
    As for a new one my yamaha place sells a brand new one for $16. I payed $18 on ebay and they laughed at me and said "Always check with us first!" Now I usually do.
    Tenaciously Deviant Unwittingly Brilliant
    Aug 2011
    2,126
    I tryed just for fun to lube old petcock under plate, no difference. I did notice on new petcock that the whole assembly is a little bigger and lever longer for better leverage.
    Sep 2012
    Northwestern Oregon
    1,092
    Fort Payne and importmech,
    Thanks for the petcock ideas. I will run my tank out and see what I can do for a fix.
    Thanks,
    Aug 2011
    2,126
    steering head bearings done. Changing shock fluid now, very dirty. about 6 ounces came out of one and 5 from the other. flushing them with atf and then using some 5wt shock fluid I already have on the shelf. I have the drain screws on mine so changing it to 10wt later will be pretty easy.
