other bike question
Results 1 to 3 of 3
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    726
    other bike question
    working on a suzuki rv 90 a two stroke bike. I got it running the other day after sitting neglected for a number of years. out on a ride it quit and wont run now. It has 120 psi compression and has spark but wont fire even if i spray starting fluid in the cylinder. I tried starting it many times but all that happened is that it started leaking fuel out the carb. Who has ideas? I think the carb thing is a seperate issue or is it related?
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    Float valve maybe bad and letting too much fuel into the engine. Is the spark plug wet?
    Frosty Hollow
    13,094
    My XT float was letting too much gas into the carb float bowl and overflowing. This also caused it to stall and not run i.e. "flooding the engine". I reset the float and all is good now.
  1. My "Other" Bike
    By scotti158 in forum Other Bikes
    Last Post: 08-06-2017, 05:24 PM
  2. An "Other Bike" ride
    By TWROG in forum Other Bikes
    Last Post: 08-15-2015, 08:06 PM
  3. Replies: 9
    Last Post: 05-22-2014, 05:15 AM
  4. My other fat tire bike
    By Ebbanflood in forum Off-Topic
    Last Post: 05-12-2014, 05:50 PM
  5. My other bike
    By robbob in forum Off-Topic
    Last Post: 06-11-2013, 06:01 PM
