Lifting TW Which side?
Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By RockyTFS
  • 2 Post By Kayak
Thread: Lifting TW Which side?
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    139
    I need to rise the TW just a few inches to service my chain. I’m using a normal car jack with a robust plank of plywood to go between jack and TW skid plate. Which side should I use? Kickstand or the opposite side? Thank you for the help
    Hailey, ID
    3,376
    Crutch jack: https://www.tw200forum.com/forum/gen...utch-jack.html
    Or, any old piece of 2x4 with a bit of a notch. The secret is to butt the front tire up against whatever with the kickstand down.
    Smitty Blackstone likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Member Kayak's Avatar
    Feb 2019
    Peru Vermont
    39
    RIMG2041.JPGIf you're looking to just clean and lube the chain, leave the kickstand down, use just the jack, and lift from the opposite side. It'll tilt the bike and make a relatively stable tripod out of it, lifting the rear wheel of the ground at the same time.
    I often use a neater method. A pair of heavy eye hooks screwed into a beam (or beams) above and a pair of ratchet straps. Lift bike by handlebars, passenger foot peg loops or rear subframe. Safe, simple and versatile. In the pic you can just see a orange strap at the bars.
    Aug 2018
    San Diego, CA
    139
    Thank you kindly.
    Feb 2017
    Waretown NJ
    556
    I lift the bike on to a metal milk crate from the chain side (left side) . I'm not going to lie. It's a small bike but it feels like it's stuck to the ground.It's heavy
    87 TW
    Senior Member sponge's Avatar
    Apr 2015
    Mesquite Nevada
    636
    Not the best quality but I have got a tone of use out of this with bunch of different bikes.
    https://www.harborfreight.com/motorc...and-65620.html
    Chris Vogel
    Current Rides
    2014 Zuma 50, 2004 TW200, 1992 R100GS, 1987 TW200
    Current Projects
    1982 550 Vision, 1986 XL600R
  1. Lifting the rear
    By Cerberus in forum Technical Help
    Last Post: 12-11-2018, 12:34 PM
  2. Lifting TW
    By c.salt in forum Technical Help
    Last Post: 01-27-2017, 11:08 AM
  3. Which side do you fall on the most?
    By Trail Woman in forum General Discussion
    Last Post: 11-16-2015, 11:03 AM
  4. Old weight lifting buddy You never know.
    By ZDR1 in forum Off-Topic
    Last Post: 11-16-2015, 08:16 AM
  5. Battery - which terminal should be on which side?
    By jimmytanko in forum Technical Help
    Last Post: 10-04-2012, 03:04 PM
