Best year? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Like Tree100Likes
Thread: Best year?
  1. #11
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,927
    Gee Gary... I can do almost 70 before shifting into 5th. And I only shut it down because I saw a new donut shop in town and had to pull over and try one of their fresh hot glazed.
    YUP! Just remember LT, when you come across the border from Canada you better stop at the nearest service station and change the air in your tires to the PSI stuff.
    1987 Yamaha BW350 Big Wheel
  2. #12
    Mar 2019
    Austin Tx
    167
    I mean, I don't think any of them are "fast," and any difference in speed by year is going to be minimal. Low miles and taken care of is all that really matters. I really liked the 2018/2019 designs (and my friend works at Yamaha with the design of those years graphics), so I went that direction. Just get one and have fun
  3. #13
    Senior Member Motoad's Avatar
    Oct 2014
    Creston, BC
    546
    My God! I never knew! Such speed!!!
  5. #14
    6,937
    Here is my '87 TW, aka T-1, 14/55 sprockets, 68mm Wiseco piston but otherwise all stock, 9360rpm and just over 65 mph.
    Here is my other '87 TW, aka T-2, 14/50 sprockets, 70mm Wiseco piston, #110 high speed jet. 8820 on the tach and just a hair over 70 mph.
    littletommy, Darth, GaryL and 2 others like this.
  6. #15
    Jun 2013
    Forestburgh, NY
    7,927
    I would love to have seen a comparison of T-1 and T-2 doing the same speed test before you made the piston, jet and sprocket changes. Bone stock and running good I had one TW that did hit 70 MPH on the speedo but on the GPS that 70 was registering as 66 MPH over the ground. On my last leg coming home there is a long flat straight just before a nice down grade before my street. I could hit 65 on the flat and just touch 70 heading down the hill before my house before slowing down. I don't know how much further I could have wound it out but I do suspect with a little longer down hill I might have been able to hit an honest 70 MPH on the GPS which would probably be reading around 75 on the speedo.
  7. #16
    6,937
    Here is T-2 at 9000 rpm with the speedo between 70 and 75. This was with a #112 jet. These speed runs are very slightly uphill -- I would call it flat except I am going against the flow of rain water.
    I had to brighten the picture a lot to see the gauges.
  8. #17
    Jun 2013
    Forestburgh, NY
    7,927
    Nice elime, I guess those Wiseco pistons do add some pep once you get the carb and gearing set right. When you go to the 70MM piston how many additional CCs does this add to the engine and how much more compression? I would suspect you are close to a 225 at this point.
  9. #18
    Senior Member jb882's Avatar
    Aug 2013
    1,374
    The only time my TW's are "Fast"...
  10. #19
    6,937
    The displacement goes up to 214cc and the compression ratio jumps to 9.9:1. The box will say 10.25:1 but that is for a 58mm stroke. The TW has a 55.7mm stroke hence the lower ratio. I would guess a 10% to 15% gain in performance. Not Earth shattering but fun to play with.
  11. #20
    Jun 2013
    Forestburgh, NY
    7,927
    Is the 70 MM piston about as far as you can bore the jug out and is the compression at close to the limits the head can take?
    Gary
    jtomelliott49 likes this.
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. Replies: 69
    Last Post: 02-21-2015, 10:54 PM
  3. best or worst year TW
    By crossent in forum General Discussion
    Last Post: 08-19-2012, 03:55 AM
  4. Best year
    By JWillett in forum General Discussion
    Last Post: 03-31-2012, 04:26 PM
  5. Best Company of the year
    By Petrus in forum Off-Topic
    Last Post: 12-03-2010, 07:14 PM
