Do you work on your TW?
Poll: Do you work on your TW? Do you enjoy it?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Like Tree120Likes
Thread: Do you work on your TW?
    Jun 2015
    Nova Scotia
    1,404
    So I'm wonder how many of you do your own work when you're able, and do you or do you not enjoy working on your bikes?
    I like having work done on my TW but would rather suffer through doing the work myself (when I can), then pay someone even if I trusted them.
    Vote, comment...etc.
    Pleasanton, CA
    5,739
    I do essentially everything except for replacing tires (but I hate carbs ). I actually enjoy working on my bikes more than I do riding them .
    Oct 2018
    Rural, South Carolina
    670
    I do all work, at all times. For better or worse lol. I learn from others and let others learn from my mistakes, but also my experience and successes. I’ve been wrenching a long time. Every time someone else touches my machines they usually screw something up. I’d rather screw it up and learn how to do it right.
    jtomelliott49, Darth, Chip and 3 others like this.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Jun 2015
    Nova Scotia
    1,404
    Having an extra set of hands relieves some frustration. Especially putting tires back on...
    Also having an organized shop and all the tools/supplies needed layed out and ready.
    Motorized bicycle carbs were easy to access and not hard to work on though very delicate...I didn't mind that so much so I'm hoping the TW carb is no harder to deal with.
    Having my only bike apart gives me a little anxiety.
    Dec 2017
    Western Washington
    212
    I do all my own work including changing the tires. About the only thing I shy away from is getting to deep into the engine. I’ll do the kick starter addition, adjust the valves, change a piston/rings or replace a head gasket, but digging into the guts of the motor isn’t something I’m interested in any more. It’s mostly because of the new way things are assembled. The tolerances are too critical and more times than not some a spring goes a flyin’ when I remove a cover or something.
    I am real particular about who works on my equipment as well. For what they charge, around $100 an hour, it better be top notch.
    TW carbs are about as simple as they can possibly be. Just get a carb diagram, use the proper tools, and lay the parts out in the order they were removed and you can hardly go wrong.
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400’s, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Mar 2015
    Ynys Môn
    4,586
    If I’ve got one or two things to do to the bike I’ll get stuck in – but if there’s a bucket load of stuff I simply haven’t got time to deal with, (like the last time I moved house just after getting the TW200, when the cat got mauled by the Doberman and the windscreen on the car cracked – long story) I’ll farm it out, but only to a place I trust (and only as far as I can throw them)
    It boils down to “how practical” is me doing the work, as opposed to how practical is getting someone else to do it. Tires, I cannot do, I’m simply not set up for it
    “Once upon a time”, I had a Honda VT250F. After a crash in the middle of London, (Baker Street), and having hit it into a skip, upside down, at speed, I sourced a new frame, and single-handedly had the lot sorted out in 24 hours. That kind of stuff I can do. Re-building the top end of a Suzi GT550 is easy, changing the clutch on a Kawasaki GT550 is simples, but if I had a mushroomed valve on the TW I would probably let someone else do it
    “If” I had a carb problem on the TW, I would simply remove it, take it indoors, and much to disgust of my wife, re-build the thing. Removing the engine, although simple in itself, followed by the top end, would perhaps “strain” the relationship. My “garage” room is severely restricted, so, it comes down to what is “practical”, rather than what is within my capabilities.
    Do I enjoy it ? – yeah – “tinkering around” with this stuff is a hobby of mine. But knowing when you’ve bitten off more than you can chew is equally as important, either in terms of difficulty, or in terms of diagnosis. When it comes to diagnosis, typically on here, is it the carb, the boots, the stator, or the CDI, or as simple as something like an ignition coil ?
    Trying to pin this stuff down is notoriously difficult, especially if it’s not your bike, and you’re trying to read in-between the lines as to what any OP is telling you. Sometimes, throwing the problem at a third party shop, who is going to do it “by the book”, one step at a time, (who can’t charge you for a part that’s been proved you don’t need, such as a CDI), makes a lot of sense. And this is another reason for “farming” out the work
    Like I said – do what you can, and accept what you (personally) can’t – it all comes back to “what’s practical”. On a project bike my opinion may differ, but when you’re burning riding time it’s not so funny …..
    - Hidden Content
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,779
    TW -
    My God, woman...after always reading your posts (always interesting, often helpful), I'd say that little carby will be a real piece o' cake! Just use JIS screwdrivers and watch that damn tiny spring that hops around like a grasshopper just before it disappears forever!
    The official Yamaha parts schematics in Partzilla.com and other vendors are your best friends. And the pro-quality TK carb images here on the Forum from member jbfla are *very* helpful.
    I'm surprised and impressed at some of the things you do & your attitudes toward riding...and please do not take that as any kind of "pretty good for a girl" BS comment. It's not.
    If you can think it, you can do it!
    I probably should put this in a PM, or not ask at all but...I & others I'm sure, would be interested in knowing something of your background.
    Education, experience, job/profession, etc.
    And "No Reply" would be perfectly understandable...
    PS - Yes, I do most of my own work.
    But I do farm out tire changes, welding, final suspension tuning, paint, upholstery and most metal polishing.
    Trail Woman, jtomelliott49 and RDW like this.
    "Faster, faster, faster, until the thrill of speed overcomes the fear of death."
    - Hunter S. Thompson
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
    Jun 2015
    Nova Scotia
    1,404
    I guess I should take another moment give some motive here...
    My TW is running well. But with some recent posts problem solving carb and valve issues and the like....I wondered how many of us are rolling up our sleeves. I'm a bit of a prepper and prefer to be as independent as possible.
    I do farm (chickens, vegetables)...but haven't been back to the dealership since they sold me the wrong oil filter and saw other bad practices there since.
    18,798
    Other than the day they were purchased my bikes have not seen a dealership. Never been to a mechanic either. A flat rear tire on a rim went to the dealership once ( a rather bad experience possibly unique to my local Yamaha shop) and have had two ATV tires spooned on a motorcycle accessory store.
    Other than that I break and fix and break again counting on good advice here to steer me in the correct repair direction.
    Senior Member mrlmd's Avatar
    1,156
    And there's that old saying that if you want something done right, do it yourself.
    One of the things you learn on the internet and on forums like this, is how to do it, if you didn't know that before. If you can read and study just a little bit, you can do anything with the knowledge you learn. Just do it.
    And if you want to take the bike to the dealer, you can talk to them intelligently and not let them bamboozle you with garbage.
  1. What do you do with your cool motorcycle stickers?
    By Ken in forum General Discussion
    Last Post: 03-07-2018, 12:39 PM
  2. Work After Work
    By Lomax in forum Off-Topic
    Last Post: 01-27-2017, 03:16 PM
  3. Replies: 13
    Last Post: 07-08-2016, 11:15 AM
  4. Had to take a day off work to go to work....
    By Flathats in forum Off-Topic
    Last Post: 06-08-2016, 05:54 AM
  5. What do you use to support your TW for work?
    By Rohnsman in forum Technical Help
    Last Post: 07-01-2014, 09:02 PM
