Learn from my mistake - re carrying spare gas tank
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree41Likes
Thread: Learn from my mistake - re carrying spare gas tank
    Member redlegsrides's Avatar
    Jan 2019
    Centennial, CO
    41
    I have a Cycleracks cargo rack and had attached a Kolpin Gas Can bracket to it to carry about 1.5 extra gallons of gas on my 2006 T-Dub.
    All had been fine till recently when I went to lift the tail end by the cargo rack and found things loose. Uh Oh.
    Turns out, the weight of the gas can had stressed things too much while trail riding I think. The bracket which is welded to the rack and provides the rear mount points on the motorcycle had broken at the weld!
    So yeah, don't do like I did.
    I hope to get it welded back up (presently camping, fixed it temporarily with holes drilled and using a bracket along with safety wire). I did crash the T-Dub while riding some gnarly ( to my limited skills) single track and the rack held up fine....Of course, the way I crashed it didn't really impact the cargo rack much, the front end took most of the impact....no damage except some more scratches on the mirrors I think.
    redlegsrides
    2006 Yamaha TW200
    1987 BMW R80
    1999 Ural Patrol with Beemer Engine.
    2014 Ural Patrol
    Pleasanton, CA
    5,740
    Quote Originally Posted by redlegsrides View Post
    That doesn't look like it is the original Cyclerack weld, but if it is, contact them and they should replace the rack for free.
    Nov 2011
    norcal nutjob
    3,324
    been there done that, mine looked exactly the same. joemama weld has held so far.
    Junior Member Hans_Hanssen's Avatar
    Jan 2018
    27
    As far as I can see, there is a long lever from the fixing points to the end of the rack. Any metal, welded or not, will crack earlier or later when constantly being bent. In consequence, it makes sense to fix at least the heavier gear at the front of the rack and lighter things behind. I saw similar problems on car racks, fixed on the back of cars. When you go off road, the weight multiplies with the acclelerated movements, and 20kg can become a force of 100kg. Good luck and happy riding!
    Spokane, Washington
    17,377
    Good Ol Joemama
    1st John 1:9
    John 3:16
    John 3:17
    18,801
    Same fuel mount caused same CycleRack fractures for me too.
    Fix that weld then watch for what fails next.
    Unfortunately carrying the fuel on the rearmost cantilevered mounting option creates the most destructive stresses.
    SanDue and NVcowboy like this.
    Senior Member SanDue's Avatar
    Feb 2015
    Happy Valley, Ca.
    629
    Hemann Rack Supports. Dirts a Flyen SanDue
    Mel, Ken, Malamute and 2 others like this.
    Senior Member NVcowboy's Avatar
    Jul 2018
    Spring Creek, NV
    591
    I actually mounted my RotoPax to the top of my Ammo box/ top box, which sits on my cycleracks. However, I also placed a (prototype) dampener to help with deflection and sway. (got it from Wersonst.) It has worked flawlessly in the year I've had it installed, plus I think the weight of the whole shebang being evenly dispersed over the rack instead of bouncing along the back bar helps greatly too.
    goldenhtr and SanDue like this.
    If you have to shoot, shoot. Don't talk. - Tuco Juan Ramierez aka "The Rat"
    There's 2 kinds of people in this world, those with guns, and those who dig. You dig. - The Man with No Name
    2018 TW200 - LCpl. Rex T. Dubber
    2010 Savage S40 650
    18,801
    That's Rex T.Dubber at Lamoille Canyon before or after the big fire?
    Jul 2018
    Spring Creek, NV
    591
    After. It was this past May actually. Below was the Lions Club camp that burned down. That's why there's no lodge or cabins visible in the picture.
    2010 Savage S40 650
