Rear Cycleracks with Rototpax?
Results 1 to 9 of 9
Like Tree5Likes
  • 2 Post By Apolloha
  • 2 Post By Fred
  • 1 Post By RaZed1
Thread: Rear Cycleracks with Rototpax?
    Junior Member feo1966's Avatar
    Jul 2019
    1
    Hi,
    I installed a rear cycleracks rack last week. Very nice. Anyone know of a "backing plate" that can be used to squeeze the top of the rack to mount a Rotopax.
    Or any other way to mount the Rotopax on top of the cycleracks?
    Thanks
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    242
    Cycleracks sell what you need:
    https://cycleracks.com/collections/p...e-bag-supports
    It also is not hard to make a mount if you have to have ROTOPAX on top.
    "Life Member NRA"
    Senior Member NVcowboy's Avatar
    Jul 2018
    Spring Creek, NV
    591
    Rotopax sells a mounting plate, flat or angled, pick your poison.
    If you have to shoot, shoot. Don't talk. - Tuco Juan Ramierez aka "The Rat"
    There's 2 kinds of people in this world, those with guns, and those who dig. You dig. - The Man with No Name
    2018 TW200 - LCpl. Rex T. Dubber
    2010 Savage S40 650
    Nov 2010
    242
    Here is one on vstrom.
    "Life Member NRA"
    Senior Member Apolloha's Avatar
    Dec 2018
    183
    I got one made for a Polaris. 90 degree. Put tank at the very back up right. Still have full use of entire rack.
    goldenhtr and Fred like this.
    2017 Apollo 250
    2018 Yamaha TW200
    1978 Suzuki DR370
    18,719
    Stock Rotopax 90 degree mount hangs off the back nicely. Good for street and mild trail work but in serious off roading the cantilevered weight out back can damage Cyclerack as well as bend 90 degrees into something like 100 degrees. I removed mine shortly after this photo. Swingarm city.jpg
    Purple and NVcowboy like this.
    Senior Member RaZed1's Avatar
    Oct 2015
    285
    Go with the flat mount. My old TW had the setup with it vertical off the back. As mentioned, for street riding it's serviceable, but bouncing around off road (with the tank full) both bent the rotopax bracket over time, and eventually snapped one of the welds on the Cyclerack mounts. I ended up selling off the rotopax and getting the Clarke tank instead.
    The cyclerack really does not stand up to much weight on there off road. I had a cooler with a 6 pack and some ice on there, few whoops alongside a railroad track was all it took to break (another) weld. They're definitely not a heavy duty item.
    Purple likes this.
    Hailey, ID
    3,341
    I just found an old aluminum solid grill and had a shop cut it to size and bolted it to the top of the rack with three strips of the same grill about an inch wide underneath the tubes and some inner tube for abrasion resistance. Then I drilled two holes for the Rotopax mount, countersunk from the bottom side for the bolts. It stays in place more or less permanently and my tail bag either goes on top of the plate or on top of the Rotopax when mounted. I also found a piece of very hard rubber to place between the bottom of the CycleRack tubing and the rear fender for more support. In 8 years I have not broken any welds on the rack.....but then I don't ride like Fred!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jul 2018
    Spring Creek, NV
    591
    2010 Savage S40 650
