What have you done with your TW today? - Page 492
Page 492 of 492 FirstFirst ... 392442482490491492
Results 4,911 to 4,914 of 4914
Like Tree11887Likes
Thread: What have you done with your TW today?
  1. #4911
    Member nathanwind's Avatar
    Jul 2018
    Saratoga NY
    53
    Rode it yesterday, but today it made the 'key rack' : )...
    Sthrnromr and admiral like this.
    2016 TW200
    & Lots of old Rovers
  2. #4912
    KL2
    KL2 is offline
    Junior Member KL2's Avatar
    Apr 2019
    Oahu
    3
    Hoping the pic works...
    nathanwind and ben2go like this.
  3. #4913
    Member Vektor's Avatar
    Dec 2018
    Newcastle, Ontario
    43
    Quote Originally Posted by KL2 View Post
    Oil change and kick start install.
    Good luck!
    Husqvarna 6440 - she may be old, but she still runs like a sewing machine.
    2006 TW200
  5. #4914
    Dec 2018
    Newcastle, Ontario
    43
    Finally got around to adjusting the air/fuel mixture screw. I was getting popping on deceleration, which I am told means it was running lean. This went away after making the air/fuel mixture... Fatter?
    The basic procedure is to remove the plug in front of the adjustment screw, tighten said screw, then untighten a certain amount. The hardest part of this is removing the plug due to it's orientation on the bottom of the carb. Some stuff I read said to remove the carb, but rotating sufficed for me. Once the plug is removed you can easily enough get a short screwdriver in there to adjust.
    I know many have done this, but for some reason I could not find pics of the procedure. Thought I'd make some as I went.
    Step 0: Turn on some tunes. I used the Ghost album Ceremony and Devotion in this instance.
    Step 1: Gather tools. I used a JIS screwdriver, small flathead screwdriver from a eyeglass kit, needle-nose pliers, Robinson screwdriver and a small screw.
    Step 1a: Feel sorry for those who do not have access to Robinson or Torx screws. They make one handed operations much easier. Helps when you are ham fisted.
    Step 2: Loosen carburetor front ring clamp (I think that's what they are called) to help allow easier carb rotation. Mine seemed to rotate without doing this, so this step may not be required.
    Step 3: Loosen carburetor rear ring clamp. Again, you may be able to skip this step.
    Step 4: Turn the handlebars to the right to release a bit of tension on the throttle cable. Rotate carburetor bottom out 45 degrees towards the choke side. This takes a bit of force so just rotate enough to access the bottom of the carb. If you feel you have to twist too hard, you may have to remove the carb.
    Step 5: Thread screw into hole in plug. I think that older TWs don't come with a hole. If that's the case, drill a small hole being careful not to mar the brass screw underneath.
    Step 6: Pry out plug. I forgot to take a pic of this step and had to edit the picture using advanced photo manipulation software. If you know what to look for you may be able to see where I altered the pic.
    Step 7: Return carb to original position, and tighten clamps. I suppose you can adjust the air/fuel mixture screw at this point, but I didn't.
    Step 8: Mark screwdriver to help when counting rotations.
    Step 9: Gently turn screw clockwise until it's all the way down. My screw from the factory needed about 1.75 turns. Now turn counterclockwise 2.5 turns.
    Step 10: Go for a ride.
    Your picture goes here
    GaryL, Sthrnromr and littletommy like this.
    2006 TW200
LinkBacks (?)
  1. Saw another TW today!!
    By mga60tw in forum General Discussion
    Last Post: 08-25-2015, 12:57 PM
  2. Could have used a kickstarter today
    By howardgene63 in forum General Discussion
    Last Post: 08-03-2013, 01:51 PM
  3. Who else rode today?
    By Matty Moo in forum General Discussion
    Last Post: 03-12-2013, 12:21 AM
  4. today's score
    By joeband in forum Performance and Customization
    Last Post: 12-11-2012, 12:29 AM
  5. Craigslist, I.E. today
    By lizrdbrth in forum TW200 Classifieds
    Last Post: 03-08-2012, 07:49 AM
cycle rack gas tank kolpin
cycleracks bag support
drag guamtw 200
high beam
matty moo sf
msr 34-2148
neutral safety switch
news
tusk hand guard for tw 200
tw200 19kgspring
tw200 carrying a treestand
yz250 seat concepts
