What have you done with your TW today? - Page 502
Page 502 of 528 FirstFirst ... 2402452492500501502503504512 ... LastLast
Results 5,011 to 5,020 of 5278
Like Tree12543Likes
Thread: What have you done with your TW today?
  1. #5011
    Senior Member BUMBLESPECIMOODA's Avatar
    Sep 2018
    OSHAWA, ONTARIO, FASCISTVILLE (I MEAN CANADA).
    159
    You're missing a spring clip on the fuel line to the carb ....
    Yup. New ones in the mail, as stock ones loosing their springyness.
    Purple likes this.
  2. #5012
    Frosty Hollow
    13,082
    Went for an almost summer solstice ride tonight since I have a Basque dinner commitment tomorrow. Crashed mildly right at top of a remote single track summit around sunset & bike just wouldn't re-start. Took well after dark to diagnose and bypass a faulty sidestand and/or neutral switch while managing to cut the fuel line. Awesome lengthy after dark ride home even though I was dripping gas.
    Saw largest meteorite fall ever.
    Made it back after 11pm & I am really in the doghouse with a justifiably worried Mrs.Fred.
    No sympathy for me tonight
    Maybe tomorrow she'll want to hear about the meteorite and why I reek of gasoline.
    I guess night riding adds "A LOT" more to the adventure! Now, if you extend the night ride to an "all night" night ride with the mixed in misadventurous items. Then you'll be in the exclusive "TW inadvertent overnight ride club"! Think how long Mrs. Fred would "let" you stay in the doghouse then haha.
    Glad you made it back, leaking lines and all.
    Purple and Dryden-Tdub like this.
  3. #5013
    18,809
    I was riding the Mr.Gizmo TW200 with the fabulous suspension that soaks up trail hack, rocks & bumps like every trail bike should. Good thing 'cause it was very rocky and I rode through several instances where the stock suspension would have had me crash.
    However the intermittent no neutral light, no starter motor function occurred when I tipped over after stalling against a rock face. This was same issue Wandering Larry had when he borrowed Mr.Gizmo in Moab. Seems the neutral switch, side stand & clutch safety interlocks are interrelated and a simple jumper shorting out the side stand enabled ignition and starter function.
    Fortunately I was with Adam who's KLX has buddy pegs so at worst case he could have hauled me 20 something miles back home.
    Fuel leak was caused by an overtightened hose clamp cutting into soft flexible fuel line accidentally done as I buttoned things back up in the darkness.
    Beautiful nice evening, will try to sneak out again Sunday night even if it means sleeping in dog house again.doghouse1.jpg
  5. #5014
    18,809
    Bumblespecimooda, Is this the one that fits newer TW200's, something like a 2003?
    KiWAV motorcycle idle mixture screw Carburetor Carb for Harley-Davidson 90-06 CV Carburetor CVK 34-36 Keihin carburetors
  6. #5015
    Senior Member mekdad's Avatar
    Jan 2012
    idaho
    189
    Quote Originally Posted by Tiny-Wheel-200 View Post
    Is that a 12 or 14 inch wheel?
    12 inch.
    Sent from my SM-N950U using Tapatalk
    You never know what you can do until you have to undo something you have done.
  7. #5016
    Junior Member Flyinspanner's Avatar
    Jun 2017
    London UK
    10
    Well I’ve got around to starting to carry on with the tear down, and buying a few bits.
    Bought a set of JIS screwdrivers.
    New twin throttle cable.
    New rear inner tube.
    Ordered up a set of rear foot pegs (missing)
    Stripped off the old horrible loom, carefully labelling each connector. It looks like it was partially “repaired” with bell wire, bits of house wire, and some terribly attached bullet connectors, or just wires twisted together and taped!
    I’ll use it to check against the much better (but not perfect ....yet) replacement loom I sourced.
    The head to carb connector looks to be in poor condition, and I’m pretty sure it may be incorrect, as it had a nasty butchered sleeve inside.
    The TK carb though externally dirty, looked very clean within, but will be getting a dunk in an ultrasonic bath. Only 3 bolts holding the float bowl on! - think I’ll switch to Allen bolts.
    Just need it to stop raining now.....
    Purple likes this.
  8. #5017
    Junior Member Krakrak's Avatar
    Apr 2019
    Laval, Quebec, Canada
    29
    Installed cheap ebay handguards, a 12v/usb dual plug on the handlebar, and did my first oil change! Only 300 miles but since it's still in break in there are never too many oil changes...
    Fred and Peterb like this.
  9. #5018
    18,809
    Instalei novas sapatas de freio em Betty Boop e limpei o filtro de ar. Ela acaba bem agora.
  10. #5019
    Sep 2018
    159
    [FONT="]Bumblespecimooda, Is this the one that fits newer TW200's, something like a 2003?[/FONT]
    [FONT="]KiWAV motorcycle idle mixture screw Carburetor Carb for Harley-Davidson 90-06 CV Carburetor CVK 34-36 Keihin carburetors[/FONT]
    That one you posted seams better than the one I got. Mine didn't come with spring washer and oring, and the threads went all the way to the knob. On mine, the skinney part where the spring goes, is longer and thinner that the stock one. I said f--k it, and put in in to see what happens. It worked. It was this one: https://cv-performance.com/ez-just-mixture-screw
  11. #5020
    Mar 2015
    Ynys Môn
    4,586
    Google translate needs some work ....
    - Hidden Content
LinkBacks (?)
  1. Saw another TW today!!
    By mga60tw in forum General Discussion
    Last Post: 08-25-2015, 12:57 PM
  2. Could have used a kickstarter today
    By howardgene63 in forum General Discussion
    Last Post: 08-03-2013, 01:51 PM
  3. Who else rode today?
    By Matty Moo in forum General Discussion
    Last Post: 03-12-2013, 12:21 AM
  4. today's score
    By joeband in forum Performance and Customization
    Last Post: 12-11-2012, 12:29 AM
  5. Craigslist, I.E. today
    By lizrdbrth in forum TW200 Classifieds
    Last Post: 03-08-2012, 07:49 AM
cycle rack gas tank kolpin
cycleracks bag support
drag guamtw 200
high beam
matty moo sf
msr 34-2148
neutral safety switch
news
tusk hand guard for tw 200
tw200 19kgspring
tw200 carrying a treestand
yz250 seat concepts
