13 tooth sprocket
Results 1 to 10 of 13
    Junior Member Honda710's Avatar
    Payson, Ut
    4
    Hi guys, I've been riding bikes for years, and have had a lot of different bikes. I needed something better suited for hunting so I decided to try the tw. I love this bike, but it seems to lack some low end grunt. It seems like most guys like to gear them up for the road, any of you gear yours down, and what sprockets did you like. I am wanting to try a 13 tooth front, but I can't find one anywhere. I went down to Rocky Mountain atv today, and went through there books, and couldn't find one. Does anybody know were I can get one or should I just try a rear sprocket, any help would be great. Thanks
    Senior Member TW2007's Avatar
    Central Washington
    464
    Quote Originally Posted by Fruitlooptw View Post
    I tried a 13 tooth front sprocket over a year ago.
    I found that the sprocket caused the chain to rub against the bike's structure way too much for my liking--- so I removed it.
    Sidewinder made this sprocket for me, (aka Krause Racing) you can look them up on the internet.
    Good Luck.
    Mike
    Senior Member SpudRider's Avatar
    Idaho
    379
    Here is a link to a thread I posted on the old forum concerning TW200 countershaft sprockets.
    https://tw200forum.com/forums/65842/ShowPost.aspx
    Spud
    Vox Populi, Vox Dei.
    Senior Member Petrus's Avatar
    Africa
    458
    Hi Fruitloop,
    At this site
    there is a calculator on which you could change the sprocket sizes to see the effect on your speed.
    I think it would be safe to suggest that a lower speed would indicate a higher amount op HP available, and vice versa.
    Lots of choices....
    Petrus
    2008 TW200
    Member Fourcycle's Avatar
    SE Michigan
    78
    I suggest going with a larger rear sprocket. If for no other reason then more teeth in contact with more links which should reduce wear.
    If your only tool is a hammer
    Everything looks like a nail
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by Fourcycle View Post
    +1 on changing the rear sprocket. I personally prefer more teeth over less. Step up to 14/54 or 14/57 for more low end pull.
    Stephen S.
    '07 TW200:
    Africa
    458
    +2
    2008 TW200
    Payson, Ut
    4
    Thanks for the info. I just put a 55 tooth on the rear, and it feels like it's going to do the trick, I'm going to go try it out in the morning.
    Central Washington
    464
    Good choice. I used that gearing configuration for most of my rides in Utah, Colorado, and Nevada over the last 3 years.
    Enjoy
    Mike
    Germany, Werdau
    1,014
    @ Fruitlooptw
    I loved my 13 in front with a 54 rear.
    It was perfect for my 125ccm engine to climb on hills.
    I have now a compareable transmission on my 200ccm MX-TW.
    I can recomment it!!!!
    You can send me a mail, if you are still interessted into it.
    Regards, Sebastian
  1. Replies: 0
  2. 13 tooth sprocket
    By PalmStateCrawler in forum Technical Help
    Last Post: 12-12-2011, 10:28 PM
  3. 60 tooth sprocket HELP
    By cthunter in forum Technical Help
    Last Post: 06-27-2011, 03:44 AM
  4. 47 tooth sprocket
    By mga60tw in forum General Discussion
    Last Post: 10-07-2010, 11:31 PM
  5. 47 Tooth Sprocket
    By FnMag in forum Performance and Customization
    Last Post: 08-26-2010, 12:26 PM
tw200 13 tooth front sprocket
tw200 13t front sprocket
tw200 60 tooth sprocket
tw200 front sprocket 13 t
yamaha tw 13 tooth front sproket
