ignition switch
Results 1 to 6 of 6
Thread: ignition switch
    Junior Member easternfrontnh's Avatar
    New Hampshire for DAMN Sure!!!
    13
    Hey!
    Has anyone changed out the key switch on there tw? The one im buying this weekend has no keys. Guy at the local yamaha shop said they dont sell keys
    So i have to replace the whole thing.
    Desert, SoCal
    7,369
    Try taking it to your local locksmith for re-keying or have him duplicate the keys.
    It ain't cheap, but remember that your helmet lock and fuel cap use the same key. It's probably cheaper than replacing all of those or the damage you'll have to do to remove them to replace them. The helmet lock needs to be unlocked to remove it from the frame. That requires an ignition key. Same for the fuel cap.
    Yamaha does sell key blanks, but they're outrageously priced. Last and only one I bought cost something like $25 IIRC. I'm sure not all locksmiths will have them but my local locksmith had the same blank for 3 bucks when it was all said and done.
    13
    Wow thanks for the heads up! I might have to use that for leverage
    Mar 2011
    Gobles, michigan
    1,824
    I had extra keys made at my local hardware..... less than $2.oo each................. "BUT" I did have the factory key for a pattern. OMM.
    13
    So if i end up going the dealer route that would give me new keys that would not git my tank and helmet lock? So id still have to call a locksmith.
    Senior Member arrowsmith's Avatar
    Missouri
    673
  1. In need of tw ignition switch and key
    By andrewsclues in forum TW200 Classifieds
    Last Post: 10-15-2012, 07:01 PM
  2. WTB: '89 Main ignition switch
    By tc339 in forum TW200 Classifieds
    Last Post: 09-14-2012, 02:07 PM
  3. New ignition switch on older bike
    By tc339 in forum Technical Help
    Last Post: 09-13-2012, 01:45 PM
  4. Ignition Switch / KEYS
    By Caribbean in forum TW200 Classifieds
    Last Post: 03-24-2011, 07:48 AM
  5. WTB Ignition switch
    By brownie2 in forum TW200 Classifieds
    Last Post: 10-04-2010, 09:23 PM
2014 key blank
2014 yamaha tw200 ignition switch replacement
ignition switch 2000 tw 200
ignition switch tw200
remove switch on a tw 200
replacement key for a yamaha tw200
tw200 remove ignition
tw200 replacement ignition keu
yamaha tw 200 igintion switch
yamaha tw200 ignition key switch
yamaha tw200 ignition switch key
