what kind of chain to buy
Results 1 to 9 of 9
    Member osheen23's Avatar
    Oct 2012
    Los Angeles,Calif.
    49
    i just bought a 13 front sprocket and 55 rear sprocket. im looking for more torque and acceleration.
    what kind of correct chain should i buy to compliment this setup well? please link me
    Apr 2013
    Central Iowa, USA
    310
    You can run whatever your pocketbook allows you. The best would be an X ring, then an O ring, and finally a non O-ring chain. The bike doesn't make enough power that it's a safety issue to run one kind over the other.
    O-ring chains are probably the balance between quiet, least maintenance, and longest life for the money.
    I plan to use cheap, non o-ring chains though because the bike is designed like farm machinery and intended to be used as such, so that's my take. I use o-ring chains on my bigger street bikes and non o ring chains on my cheaper, older (and smaller) bikes.
    1993 TW200
    Oct 2012
    Los Angeles,Calif.
    49
    Quote Originally Posted by silverhead View Post
    what size should i get? can you provide me a link please
    i bought as 13/55 sprocket setup
    Hailey, ID
    3,329
    Quote Originally Posted by osheen View Post
    13/55 will need a 124 link chain.
    http://www.rockymountainatvmc.com/p/...X-X-Ring-Chain
    You will have to cut it down to 124, I could never find a 124 anywhere.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    I've heard / read that when an o-ring is installed that the bike "seems" slower?.This of course could be true until the o-rings "break-in'?....don't know.Then again,the o-ring chain could really be affecting the mighty 196cc's our TW's have,again,don't know?.
    Oct 2012
    Los Angeles,Calif.
    49
    hiow do i cut it down?
    Senior Member bbagwell's Avatar
    Salem, Oregon
    421
    I used a DID 428 o-ring chain. To cut it down get a chain breaker and take out the desired number of links, then use a master link to install the chain.
    Bryan Bagwell
    1995 Yamaha TW200
    1983 Toyota PU
    2002 Suzuki Grand Vitara
    Hailey, ID
    3,329
    Rocky Mtn had a nice chainbreaker for $20.
    Or take it to a dealer or mechanic, it's so easy they shouldn't charge you even $20. But make DAMN sure it gets cut in the right place!!!!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Hailey, ID
    3,329
    Quote Originally Posted by frog13 View Post
    OWT
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. new seat--kind of
    Last Post: 06-22-2013, 07:30 PM
  2. Chain
    Last Post: 07-25-2012, 09:32 PM
  3. What kind of oil is recommended?
    By Beewerks in forum Technical Help
    Last Post: 07-24-2011, 08:48 PM
  4. Kind of a failed ride report
    By dhoenisch in forum Trails, Off-road, and Adventure Riding
    Last Post: 06-01-2011, 08:18 AM
  5. help chain
    By Logan in forum General Discussion
    Last Post: 01-25-2011, 09:18 AM
