Does the TW200 have a 'beeper' in the turn signal?
Results 1 to 10 of 10
    Apr 2013
    Central Iowa, USA
    310
    My TW200 has one of those annoying old man beepers when you use the turn signal. They're embarrassing at stop lights and annoying.
    Was this a factory thing or did a previous owner install it? I spent about 30 seconds trying to track it down and stab it with a screwdriver, but the sound is non-directional and I'm half deaf as it is. I want to remove it but I was curious if this was something that came with the bike or not.
    Someone also wired up these really annoying LED dazzler/flasher lights to my brake light. So at a stop light I'm giving the person behind me a seizure. I can leave those because I need all the help I can get when turning into my driveway (I live on a highway on the edge of town and people nearly rear end me several times per year because they're not paying attention.)
    But the beeper must be silenced. I've kept them on other bikes since they are stock, but I put electrical tape over them so they muted out.
    1993 TW200
    Member Uwdlk2no2's Avatar
    Dec 2012
    Mississippi
    84
    I have a 2013 and it doesnt have any kind of beeper on the turn signal. I have to pay attention and turn it off. I suspect someone added it.
    Lance
    2013 TW200
    2003 TW200 (Wife's Bike)
    2013 Ultra Classic Limited
    2008 Street Glide
    Aug 2011
    Cayce, SC
    3,109
    It is a small aftermarket box that can be added. If you track it down, send it my way!
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Apr 2013
    Central Iowa, USA
    310
    I dug in and found the culprit(s.) Two Radio Shack piezo electric beepers. They both had electrical tape over the hole, so they were way louder without. They were wired goofy as well, utilizing snap connectors to the bulb wiring and playing on the principal that the TW turn signal circuit reverses polarity depending on which way you flip the switch.
    So dumb.. They're gone now. I took the opportunity to replace the neutral and high beam lamps with white LED bulbs. The turn signal can't be replaced due to the aforementioned polarity issue when you are using the signal one of the two directions.
    I also pried off that stupid 'neutral tube' they had installed with JB Weld. It took some of the plastic, but at least I can see the whole lens cover now. Here's a shot with the two LED lamps as well as the turn lamp lit up all at once.
    1993 TW200
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    The turn signal bulb can be replaced with a LED, just make sure you get an AC/DC bulb. Works great on mine.
    Apr 2013
    Central Iowa, USA
    310
    I had a ten pack of these LED bulbs sitting at home. I want to get one of those AC/DC ones as well as a 'wedge' bulb for the speedo.
    Even though it's backlit as yellow (how fashion forward!)
    I proceeded to drive for about a mile today with my right turn signal on after removing the beeper.
    But the good news was that I was on the way to the Yamaha dealer to pick up my fancy new replacement cover for the lights.
    1993 TW200
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by silverhead View Post
    What is the part # for this cover with the amber turn indicator? It really bugs me mine is green, this should be for neutral only...
    Jul 2012
    Wet-ern Washington
    1,409
    Bugged me too. Read this.
    - Leisure Time Larry -
    rbm
    rbm is offline
    Jan 2011
    4,300
    Quote Originally Posted by lrppcer View Post
    Thanks! I knew I read this before...
    Apr 2013
    Central Iowa, USA
    310
    Yep, that's the part number I used. 15A-83568-00-00
    I just paid my dealer the 26 bucks.. I get gouged on shipping from those online places and it ends up being cheaper to just support my local guy.
    1993 TW200
  1. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  2. Turn Signal Wiring
    By Jtrez in forum Technical Help
    Last Post: 12-21-2012, 04:01 PM
  3. LED turn signal heads up
    By operose in forum Technical Help
    Last Post: 03-24-2012, 09:33 AM
  4. WTB - Turn signal lens.
    Last Post: 11-04-2011, 08:30 AM
  5. Vapor Turn Signal Kit Help
    By Justin5117 in forum Technical Help
    Last Post: 11-12-2010, 08:20 AM
correct yamaha tw200 motorcycle rear turn signal bulb number
you tube yamaha tw 200 replacement turn signal lights for standard lights
