Did the cycleracks change
Results 1 to 9 of 9
    Member Uwdlk2no2's Avatar
    Dec 2012
    Mississippi
    84
    I recently purchased a rear rack from Cycleracks. However, In every picture I've seen in multiple tw200 forums, with the exception of one, all of the rear racks have the 90 degree upturn at the rear of the rack. This forms a sort of handle and would help to stabalize and hold anything riding on the rack in place. My cyclerack does not have this 90 degree upturn. Did they change how they were making the rack? Did I somehow not get the correct rack. It bolted right up took maybe 10 minutes to install. Emailing the manufacturer has resulted in no answer to the question. Anyone here know if or why they changed the design.
    Thanks,
    Lance
    2013 TW200
    2003 TW200 (Wife's Bike)
    2013 Ultra Classic Limited
    2008 Street Glide
    Senior Member rm_hm's Avatar
    1,619
    Give Don at cycleracks a call. The guy is super nice.
    Phone/Fax: 208 424-9311
    I've heard folks talk about special ordering the racks without the upturn.
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    I got mine a couple months ago and I received it with the upturn. I think I got it in Feb.
    -Szj
    2001 TW
    Senior Member stephenmarklay's Avatar
    Mar 2012
    Spokane, WA USA
    493
    Quote Originally Posted by Sweetzombiejesus View Post
    Yes mine has the upturn and it is pretty new.
    2011 TW200: Protaper Fat Bars, IMS Pegs, Cyclerack, Moose Racing Tail Bag, Cyrca Handguards, VStrom Mirrors, Jimbo Shield, Oxford Heated Grips, ProCycle 15k spring, 2x2cycles rack, seat concepts, Cyclops Adventure Sports LED conversion
    2014 BMW F800GS
    2007 BMW R1200R
    Sep 2012
    Northwestern Oregon
    1,092
    For what it's worth, my (older) Cyclerack does have the upturn and I would rather have the model without the upturn. The upturn has some benefits, but if you want to mount a larger "trunk" or case on the back it can be advantageous to have a flat rack.
    Nov 2011
    norcal nutjob
    3,309
    i recall just reading some one paid $10 extra for the downward curve. they must have somehow shipped you one of those.
    i'd bet they will swap you for an upturn with no problems. there customer service was A+ for me.
    Senior Member atleastbehandy's Avatar
    Apr 2011
    Toronto, Canada
    250
    I ordered the cyclerack without the 90 degree bend; just called Don, and he was very helpful.
    The reason I wanted it straight was so my top case would fit (Don said many people haul "meat" so the 90 degree bend is needed to keep stuff from slipping off the back).
    Mine still works just fine as a handle. And I have even used it to hold the rear tire off the ground to oil my chain.
    2005 TW200, 2" PowerMadd bar riser, Tusk D-Flex Hand Guards, PowerMadd Hand Muffs, Kick-Start, Valco Cup Holder, Givi E45N Top Case, Inline fuel filter, Storage Tube with MSR bottle, 45 Tooth sprocket, Stebel Low Tone horn, #130 Main Jet / no needle shims / 1.5 turns out on idle, Jimbo Shield, DID O-Ring chain, Clarke XT250 4.1 Gal tank, Custom Cycleracks
    RIF
    RIF is offline
    Junior Member RIF's Avatar
    20
    I have one with the upturn, wish that I would have gone with a flat deck on mine.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by Rich View Post
    As Rich advised,call Don,he is easy to get along with.
  1. Cycleracks Bag Supports
    By retmotor in forum Performance and Customization
    Last Post: 02-12-2014, 05:48 PM
  2. Cycleracks????????
    By Swamp in forum Technical Help
    Last Post: 05-25-2013, 06:29 PM
  3. Cycleracks
    By mtkd in forum General Discussion
    Last Post: 02-11-2013, 09:48 AM
  4. Cycleracks Success At Last!
    By DonBenito in forum General Discussion
    Last Post: 09-01-2012, 03:01 AM
  5. Cycleracks Installation
    By royalman in forum General Discussion
    Last Post: 07-10-2011, 04:55 PM
2013tw200rearrackfitissues
cycleracks tool tube
