Octane levels
Results 1 to 6 of 6
Thread: Octane levels
    Junior Member glassyandsunny's Avatar
    Apr 2013
    13
    Do different octane levels affect the performance or mileage on the T Dub? Thanks
    Mar 2011
    Gobles, michigan
    1,824
    The rule is use the lowest # of octane that will not cause pinging. If the motor pings then go up from 87 / 89. It's just pouring $$$ out the window with higher octanes. OMM.
    Senior Member David G.'s Avatar
    Aug 2011
    Springfield, Oregon
    107
    My bike doesn't run any differant on any other octain levels, so I just buy the cheap stuff.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Go with what the manual advises.....usually the compression of a particular engine determines the octane....I know,there are more factors than just compression ratio.87 is just fine with TW's.
    Apr 2013
    Central Iowa, USA
    310
    I get pinging noises out of some of my motorcycles on 87 octane gas when it's really hot outside, say 100+ degrees and I have left the bike idling at a stop. When I take off it's "plink plink plink" as I leave 1st gear. I have solved the problem on those bikes by using 91 octane gas.
    So far I have not heard any signs of it on my TW and I was riding it off road in 95F weather just two days ago. The only difference I was feeling was my clutch. The engine sounded like a sewing machine the whole time (which is good.)
    1993 TW200
    May 2013
    Groton, NY
    2,663
    I get a little pinging during extended slow speed trail riding at low rpm's if I use 87 octane.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
  1. Best strategy to fix Low battery acid levels
    By drifterthruthemtns in forum Technical Help
    Last Post: 05-07-2013, 12:04 AM
  2. T-DUB Reccomended Oil, and Octane Rating?
    By Swamp in forum Technical Help
    Last Post: 04-10-2013, 06:47 AM
  3. Octane rating?
    By kenfyoozed in forum Performance and Customization
    Last Post: 10-23-2012, 03:22 PM
2013 tw200 octane
pinging tw200
tw200 pinging
