Stupid Handle Bar Question...
Results 1 to 10 of 15
    Member bsullivan161's Avatar
    Apr 2013
    Jersey Shore
    30
    Yes, I'm a newb with some of this stuff...sorry . So, I just bought the Pro Taper bars as it seems they would be easiest to install...Well, not for me...LOL. Two questions...1. The numbers on the ends of the bars seem to indicate where you would maybe cut the bars to match the stock length of the exsisting bars? Is that right? Otherwise, it doesn't seem that the cables will be long enough without getting new ones. Seconds, I'm assuming that I have to cut off the stock grips and get new ones?
    Thanks for the patience guys. I went up one tooth on the front sprocket and it has made a huge difference on the street!!!
    Member Drifter's Avatar
    Aug 2012
    Lewiston,Idaho
    96
    Quote Originally Posted by bsullivan161 View Post
    Welcome,I have a 94 model with the protaper bars,and I left them at stock length.I had to reroute some cables is all.And yes you will need new grips.P.S. cut or don't cut, it's a personal choice.Myself I like the extra added length.
    1994 TW
    Had but regrettably sold a 1982 KZ1000R Eddie Lawson Replica
    Apr 2013
    Jersey Shore
    30
    Quote Originally Posted by Drifter View Post
    So you're saying that, although the new bars are about an inch longer, that the stock cables should be fine?
    Aug 2012
    Lewiston,Idaho
    96
    They work fine for me on my 94.
    1994 TW
    Member Dako124's Avatar
    May 2013
    Wickenburg,AZ
    43
    You can get nicer grips really cheap but if you want to keep yours blow under them with air from a compressor and they slip off way easier.
    Senior Member Dubster's Avatar
    Nova Scotia Canada
    583
    I have the ProTaper bars on both my TW's and with a little rerouting of the cables they work just fine.I like the added width.
    Stick the tube under the grips and spray some WD-40 in there and they will slip right off.
    09 DL650 V-Strom "Function over Form at a Superior Price"
    09 DR650 "Hooliganizer"
    03 TW200 "No Road---No Problem"
    81 Z50 "Just Because"
    98 Honda Valkyrie "Fast as [email protected]&K"
    02 Tw200 " Camouflaged Redneck Edition" Sold to Son-in-Law
    73CT Trail90 "The most fun you can have under 100cc's" Sold. Had an offer I couldn't refuse.
    Apr 2013
    Jersey Shore
    30
    Man, you guys are awesome...thanks a lot! If I can figure out how to get a picture on here, I'll upload one...
    Apr 2013
    Jersey Shore
    30
    Ok..DONE! The WD-40 worked like a charm. I had to drill a couple of small holes into the new bars since the throttle and one other part had a small 'plug' to fit or be placed at a certain angle...no problem. Re-routing the cables took a bit of thinking, but all done. The new bars look and feel great. Thanks everyone!
    Pleasanton, CA
    5,712
    Congratulations!
    It is nice to have you report back on your success.
    Apr 2013
    Jersey Shore
    30
    Hey Brian, can you tell me how to post a picture? In other forums that I go to, you simply hit the 'insert image' link and find it on your computer. Seems this site is different?
  1. Ever Done Something So Stupid?
    By thumper in forum General Discussion
    Last Post: 10-30-2013, 07:11 PM
  2. Stupid question?
    By BC4Lyphe in forum Technical Help
    Last Post: 05-24-2013, 12:10 AM
  3. i did something really stupid
    By erica in forum Technical Help
    Last Post: 05-13-2013, 04:58 PM
  4. stupid gasket leak
    By old mad max in forum Technical Help
    Last Post: 04-05-2013, 09:22 PM
  5. I did something stupid.....
    By kenfyoozed in forum General Discussion
    Last Post: 12-04-2012, 11:18 AM
