TW200 base gasket replace o-ring fell inside
Results 1 to 3 of 3
    Junior Member BMKTW2's Avatar
    Jun 2012
    16
    Thumbs up TW200 base gasket replace o-ring fell inside
    First off I just want to say my 2007 tw200 was bought new by me and has 6,000 miles on it. The base gasket has been leaking since ~4,000 miles.
    It makes my blood boil to think I'm doing this work after I paid over$4,000 on a motorcycle which has been in production for many many years.
    I would not recommend this bike to anyone.
    Onward to the task at hand...
    I was putting the new gasket on...... Here in this picture everything is going just fine and dandy...
    Then as I was lowering the piston into the bore I made a final check on the gasket and o-ring.
    The o-ring is missing.
    I looked all over... It must have fallen inside. I used my super bright flashlight but I see nothing.
    I turned the engine upside down, I sprayed WD-40 inside, I srayed with the air compressor and no sight of the o-ring.
    I'm stressing really hard right now. I dont want to tare the engine down, I might mess something ELSE UP. I just want to give up. I've not felt like this in many years. Its alot of frustration between this bike and my truck which jfsklefjgsdlf is somewhat in the same senario where the new camshaft got destroyed and i have to pull the engine bac out
    '07TW200 '02Sherco290
    Jun 2012
    16
    I found it!!!!
    Soo lucky....
    WD-40 got it to slide down to the bottom and I saw it with my flashlight. I bent a piece of metal wire into a hook and fished it out.
    Mar 2011
    Gobles, michigan
    1,824
    "Oils" well that ends well. (o; I have an 06 and mine also leaks... Not happy with mine either... "UNTIL" I ride it.. Then I forget about it.. OMM.
  1. wrong base gasket?
    By BoatHands in forum Technical Help
    Last Post: 04-08-2013, 10:17 PM
  2. Did my base gasket today
    By Guitarman in forum Technical Help
    Last Post: 06-18-2012, 12:47 PM
  3. Base gasket leaking
    By sensor419 in forum Technical Help
    Last Post: 03-27-2012, 09:07 PM
  4. 07 base gasket leak
    By small's in forum Technical Help
    Last Post: 03-25-2012, 09:41 AM
  5. Should I replace the base gasket--2006
    By dganey in forum Technical Help
    Last Post: 05-05-2011, 08:20 PM
gasket change tw200 base
tw200 engine o ring
Tags for this Thread
