Teen project or not?
Results 1 to 10 of 11
    Junior Member Megawisdumb's Avatar
    Jun 2013
    Alabama
    10
    My son's 2006 TW appears to have broken a valve stem on the intake side as its free flowing and the nut is missing. It runs fine aside from loud tapping which we powered down as soon as noise started. I'm not certain all the steps necessary to remedy this issue and would like to hand him (16) a repair manual and buy him the parts he needs. He has replaced his instrument cluster in his tacoma so he is somewhat techie....is this a 16 yr old project? Bike has 3200 miles.
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    503
    he ain't gonna learn any younger. TIM
    Member lorddaftbiker's Avatar
    Jun 2011
    94
    If he has mechanical ability and can use you as a resource, yes it is. If not, the results may not be so good. Good luck!
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Just make sure he has the tools he needs and the manual (I always prefer a hard copy), as long as he has mechanical ability he'll be fine. He has to start sometime ...
    Jun 2013
    Alabama
    10
    Upon further viewing..Im thinking it just lost its nut..see picture. Any idea where I might find nut?twValve.JPG
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    In the crankcase, unfortunately.
    Or worse yet, stuck halfway down in one of the holes the oil flows through.
    Stephen S.
    '07 TW200:
    Jan 2012
    northeast ohio
    503
    should be right there in the 'pocket'. Good light, mirror, and a magnet. Might get lucky. TIM
    Jun 2013
    Alabama
    10
    Pocket as in valve area? I drained the oil and pulled the side crankcase off and searched around to no avail.
    rbm
    rbm is offline
    Jan 2011
    4,300
    Quote Originally Posted by tinman tim View Post
    This, look around in the top of the engine. I've never had mine apart but are the oil passages large enough the nut could fall down into the crankcase?
    Senior Member kdick91's Avatar
    Sep 2012
    TX
    188
    When I had this happen, I took the chance to replace the base gasket and have the head on a bench for my inspection. If you have not replaced the base gasket, now might be a good time to do so! Having recently been 16 (22 now) and knowing my abilities then, I think it's possible for your son to do this under adult supervision. With most things automotive, there is a right way and a million wrong ways. With changing the base gasket, it really is basic wrenching. That being said, there is a specific order in which things are supposed to be done. All you need is the gaskets, a torque wench, and patience. And with the head off, it will make it 1000x times easier to find the lost nut. Mine happened to be within about 2" of the valve lodged in a little crevice in the head. I could not see it with the head on and when I shook the head, it did not rattle... It really was lodged, but a good magnet plucked it out! And, bonus, my base gasket isn't leaking! FWIW, I also have an '06, that gasket will give up on you. For added comfort, I got a new bolt and lock nut for the valve. After getting loose, it strikes the valve in angles and gaps that it isn't supposed to. It was $3 insurance for me. Feel free to reply on here if you have problems. I'm sure someone will be able to help you get things done if you have any problems. Don't forget you also need a feeler gauge set for valve lash!!!
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2015 WR250R - Bored, stroked
    Gone - 2000 Trans Am
    Stolen - 2007 Trailblazer SS
    2014 Jeep Grand Cherokee SRT
    1977 Steyr-Puch Pinzgauer 710M
    2 Timothy 1:7
  1. My 88 project
    By trailway in forum Performance and Customization
    Last Post: 12-22-2012, 08:19 AM
  2. My 88 project
    Last Post: 12-21-2012, 04:01 PM
  3. New project
    By Mame Shiba in forum Performance and Customization
    Last Post: 02-14-2012, 02:18 PM
  4. New Project
    Last Post: 06-05-2011, 05:35 AM
  5. New Project
    By Mame Shiba in forum Off-Topic
    Last Post: 06-04-2011, 02:03 AM
