Tire Pressure....
Results 1 to 4 of 4
    Member bsullivan161's Avatar
    Apr 2013
    Jersey Shore
    30
    Tire Pressure....
    I have to admit that I don't check tire pressure as often as I should. I just checked it and my rear was 32 and front was 30. When I looked in the manual, it has psi closer to 25 rear and 20 front. Is that right? I'm sure off road you guys keep it a bit lower, but on the street? Just curious what you guys keep yours at for street riding? Thanks!
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    I run 20psi front and rear, for street or dirt.
    Hailey, ID
    3,329
    Quote Originally Posted by bsullivan161 View Post
    My 2010 manual says 18 front 22 rear. 18/25 when at max load. 30/32 is REAL high, you're not going to get much tire mileage at that pressure. Your MPG will be better, though. I routinely run both mine at 12, but I'm only going 5 miles on the pavement. If I was doing more than that I'd go up to the recommended pressure.
    Motorcycle tires lose pressure faster than car tires, they should be checked once a month.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Apr 2013
    Jersey Shore
    30
    Thanks guys. The bike was feeling a little harsh over bumps...Now I know why! By the way, this is how she came from the dealer...they obviously didn't know what pressure to put them at!
  1. Tire pressure
    By Drifter in forum Technical Help
    Last Post: 10-10-2012, 05:52 PM
  2. tire pressure
    By ridgeline in forum General Discussion
    Last Post: 09-18-2012, 07:27 PM
  3. How Low do You Go tire pressure
    By Stromper in forum General Discussion
    Last Post: 07-21-2012, 07:50 PM
  4. Tire Pressure On The Fly
    By thumper in forum General Discussion
    Last Post: 11-22-2010, 01:02 PM
  5. TIRE PRESSURE
    By Turtle Chaser in forum General Discussion
    Last Post: 09-24-2010, 07:08 PM
