Things to look for in a used tw
Results 1 to 10 of 11
    Junior Member Treeplanter's Avatar
    Dec 2012
    Vancouver, BC
    8
    Sorry if this is not the right spot but;
    I'm going to take a look at a used TW tomorrow, its a 92. The add doesnt mention miles. Are there any TW specific weaknesses (I know there is a better word but after a brew or two the mental dictionary fails) I should be looking for? Weeping fluid from a sneaky spot, odd gear shifts that I might miss, vibrations or noises...that kind of thing. My only other bike was a beater Suzuki 600 that I learned on that wouldn't hold 2nd gear. I didnt really care cus it was so cheap. But I have BIG plans for my Dub, wherever I find it.
    Thanks a bunch.
    Senior Member liquidsilver's Avatar
    Oct 2010
    SW Washington
    104
    Bent handlebars and levers.
    Missing tool kit.
    Broken housing for Speedo and indicator lights.
    Fractured turn signal stalks
    Bent / warped brake disks
    Working brake light (validates switch)
    Working neutral light (validates switch)
    Working speedo
    Sent from my iPad using Tapatalk HD
    Richard (a.k.a. LiquidSilver)
    __________________________________________________ ________________________________________
    91 TW200 aka "The Mule" :-)
    03 VRSCA / 05 Polaris Sportsman 500 / Honda Helix CN250[/color]
    6,971
    Look around the base of the cylinder and if you see an oil leak hammer the seller on the price. Ditto the valve covers. All the older bikes either leak or will leak but the fix isn't to bad.
    Look at the chain -- if rusty and stiff the price goes down. Remember a new chain also means new sprockets -- not always but tell the seller to do it right means new sprockets.
    If it runs well is what really matters. Everything else can be easily fixed.
    Hopefully the seller isn't a member of this forum.
    Senior Member kdick91's Avatar
    Sep 2012
    TX
    188
    A Tdub basically has one moving part. If it fires, runs, and stops fine, you are pretty much good to go on everything major! Most signs of neglect will be obvious. Look in the oil level sight glass to check color of oil, look around the base of the cylinder to see if the base gasket is leaking (most common issue), make sure the clutch return spring is in the correct location, check for kinks in the chain (though you'd want to replace it ASAP anyways, the factory chain is not of high quality), and just make sure the bike looks straight. Being a single-cylinder, air cooled engine, it doesn't get more simple. If you have ridden a known healthy TW, you can really judge by the seat of your pants. On a 92, outside of maintenance, just make sure all switches still work and make sure it has healthy, linear torque throughout the RPM range. I'd bet the carb could use a good cleaning regardless though. Just curious, what's the mileage and price on the bike?? Can't wait for you to join the club!
    Kyle
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2015 WR250R - Bored, stroked
    Gone - 2000 Trans Am
    Stolen - 2007 Trailblazer SS
    2014 Jeep Grand Cherokee SRT
    1977 Steyr-Puch Pinzgauer 710M
    2 Timothy 1:7
    Dec 2012
    Vancouver, BC
    8
    Thanks a lot for all your info. I'll let you guys know how she goes tomorrow.
    The mileage wasnt listed in the ad, and the price is $1300
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,021
    I paid $1500 for my '91 but it had 675 miles and was in pristine condition with zero rust and zero abuse. It suffers more from lack of use with nasty old fuel in the tank and carb.
    Abuse and neglect is easy to see as are hard miles.
    If you do buy it then come back and start reading. I would not put any miles on any new to me bike without a total going through no matter what the previous owner tells you. Oil change, carb cleaning, valve and timing chain adjust, check all cables and breaks, check all lights and electrics, new plug, air filter and ad a fuel filter after you dump the tank and add fresh fuel. Check chain and sprockets and adjust.
    1987 Yamaha BW350 Big Wheel
    Dec 2012
    Vancouver, BC
    8
    thanks for all your help guys. i didnt make an offer to the guy. it felt ok to ride, but the tranny didnt engage until the cluth was almost all of the way let go, and the bike was cosmetically not pretty. it started right p and came with a few extra parts but just seemed a bit too rough. again thanks for all your help, it will come in handy in the future.
    KC
    edit: 10k miles, sorry
    Jun 2013
    Forestburgh, NY
    8,021
    It is a very common occurrence that people decide to sell right around the time things are in need of some repairs. Rough looking is a good indicator of hard riding or abuse and maybe even some neglect in the maintenance department. Replacing the clutch is no big deal and most other things on a T dub are pretty straight forward if you have some wrenching under your belt.
    Price is the key when you are looking at used bikes! You didn't say what the miles on the bike were or if you could even be reasonably sure they are accurate. Walking away from a questionable purchase is a good idea and gives you some more time to save a few more nickels for when you find a nice T dub. You might want to mention where you are so others can tip you when they know of other bikes in you general area. We have all seen some nice dubs at fair prices and some real rats with ridiculous price tags.
    The funny thing about TWs is the year model is not as important where price is concerned as the condition. An older unit in pristine condition with low miles could be as valuable as a fairly new but well used bike. They just don't change all that much year to year so a 1990 could be just as good a deal as a 2005 at the same price. Keep in mind the newer ones come with no kick start so that could be a deal breaker for some guys. Most of the other changes over the years are minor in my opinion.
    Stanwood,Wa
    1,880
    Treeplanter, Fill out your profile so we know where you live. There may be some members close by that can keep an eye out and help. Good luck on your search.
    Frosty Hollow
    13,031
    Quote Originally Posted by Treeplanter View Post
    This is very common and just the way TW clutch engagement is/feels. Should you have a chance to test ride other TW's, you'll see, so don't let this be a show stopper while shopping around for a TW.
  1. Need a few things
    By BC4Lyphe in forum TW200 Classifieds
    Last Post: 02-28-2013, 09:10 PM
  2. Dead things seen from my TW
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-28-2011, 03:27 PM
  3. The simple things..
    By jontow in forum Performance and Customization
    Last Post: 08-25-2011, 11:40 AM
  4. Things to do
    By phelonius in forum General Discussion
    Last Post: 03-25-2011, 05:36 PM
  5. Different ways of looking at things...
    By Petrus in forum Off-Topic
    Last Post: 09-15-2010, 09:07 PM
