Engine tuning for beginners
Results 1 to 4 of 4
    Senior Member MCC1776's Avatar
    Jul 2013
    Dallas, TX
    395
    The only thing I've done to the engine since I've bought the TW back in July is two oil changes and I pulled the LS engine cover when I did the sprockets/chain/gasket change. I know these engines are tough as nails, but I'd love some advice on what I need to keep up on engine maintenance wise and what the intervals are. Any helpful threads for beginners who have never pulled apart a motorcycle engine before would be awesome. Thanks everyone.
    1987 TW200
    Cycleracks Rear Rack, Tinman Tim's Side Racks [THANKS!], Action Packer Rear Trunk, Texsport waterproof luggage, 20w LED Spot Beam headlight, LED Bulbs for Rear Brake Light and Dash/Speedo, 12v marine auxiliary port, Coleman Seat Pad, Alloy Boltz kit.
    "I will prepare and someday my chance will come." -A. Lincoln
    Spokane, Washington
    17,416
    In the owners manual which is downloadable, there is a chart which shows what should be done and when.
    It is in the technical area under sub-forums.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    Jul 2013
    Dallas, TX
    395
    my laptop wouldn't download the pdf for some reason, but the iphone did just fine. Thanks guys. Any one thing I should look to first?
    1987 TW200
  1. Carb tuning help!!!
    By FloridaDub in forum Technical Help
    Last Post: 04-17-2013, 10:36 AM
  2. Beginners Guide to Base Gasket Replacement
    By B-dub in forum Technical Help
    Last Post: 08-17-2011, 10:01 PM
  3. Beginners Guide to Base Gasket Replacement
    By B-dub in forum Technical Write-Ups
  4. Carb Tuning
    By qwerty in forum Technical Help
    Last Post: 10-03-2010, 05:16 AM
  5. Carb Tuning
    By qwerty in forum Technical Write-Ups
