Kicker and Pusher
Results 1 to 10 of 13
Like Tree1Likes
Thread: Kicker and Pusher
    Senior Member Mongol Pete's Avatar
    Oct 2013
    Ulaanbaatar, Mongolia
    143
    Question Kicker and Pusher
    Hello Tdubbers,
    Which years have kick and electric start please.
    Thanks,
    MP
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    1987 through 2000
    Mar 2011
    Gobles, michigan
    1,824
    And they have front drum brakes... OMM.
    Oct 2013
    143
    thanks fellas....now, is it worth the trade-off to have the extra starting power, but inferior stopping power...decisions decisions
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    The difference in braking is tiny, the disc isn't much of an improvement. I've owned both and I prefer the drum, no seals, O rings, hoses or master cylinders to leak and go bad.
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    If you find an old enough drum brake one it'll have drains that make changing fork oil EASY. I think it was around '95 they lost the drains, but the casting boss is there. I had the lowers on my '99 drilled and tapped for drains when I built Lzrdbrth franken forks. There is no boss on the '04 disc brake lowers.
    I've about decided to convert my '04 to drum with drains.
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
    Oct 2013
    143
    thanks fellers...sounds like 87-00 is the way to go....any other differences in the years I might look for?
    best from UB, MN
    MP
    Desert, SoCal
    7,369
    https://tw200forum.com/forum/general-...t-year-tw.html
    How much of a liability are the genuine Japanese bikes over there? Always wondered what the parts situation might be.
    I think Spudrider has freely exchanged a number of Zongshen engine parts with Yamaha parts so I'm assuming the reverse would be true. I know some of the indigenous knockoffs run fat 15" rear tires but what's the sitch on 14's?
    Senior Member MCC1776's Avatar
    Jul 2013
    Dallas, TX
    395
    Don't get the first model year. My 87 has a totally unique electrical system. Stick with the 88-00
    1987 TW200
    Cycleracks Rear Rack, Tinman Tim's Side Racks [THANKS!], Action Packer Rear Trunk, Texsport waterproof luggage, 20w LED Spot Beam headlight, LED Bulbs for Rear Brake Light and Dash/Speedo, 12v marine auxiliary port, Coleman Seat Pad, Alloy Boltz kit.
    "I will prepare and someday my chance will come." -A. Lincoln
    Oct 2013
    143
    thanks for the heads up MCC
    LZRD - I have just only begun to check out bringing a Jap TW over to Mongolia....so far it hasn't been too easy to get clear info, but I'm on it....only been here 6 weeks, and sometimes I gotta work :-(
  1. WTB: footpegs, rear pegs, brake lever and kicker - '92
    By wdaloz in forum TW200 Classifieds
    Last Post: 10-10-2012, 10:55 PM
  2. Kicker
    By Larry in forum General Discussion
    Last Post: 08-01-2010, 09:16 AM
