Tried a quick GPS mount.
Results 1 to 7 of 7
    Senior Member Little General's Avatar
    Jul 2013
    Mt Pleasant, NC
    188
    Took my GPS out of the H1 today and Velcroed it to the seat for a test run today. Learned 2 things, first 55 mph is 53 actual and having your GPS mounted at the top of the tank is very hard to see. Because of its size I couldn't find a handle bar mount and it takes up most of the dash area if mounted behind the windscreen. Where do you guys mount your GPS and what brand works best.
    Aug 2011
    Cayce, SC
    3,109
    Ram mounts
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Ram mounts
    Second that.
    Sep 2012
    Northwestern Oregon
    1,092
    Ram mounts
    Third that.
    There are so many different options they are kind of like Lego for adults. You can get them to fit anything.
    Senior Member Braden's Avatar
    Jul 2013
    Toronto, ON
    236
    At a cost.
    Sent from my One using Tapatalk
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    503
    Heres my set-up. Old TomTom1 ver3, and my iphone next to it. Custom aluminum bracket holds both. Up and out of the way enuff to still see the gauges/indicators. It is a RamMount holder that it clips into
    SeatConcepts,carb mod,Shinko tires,15/50 o-ring chain,custom racks f/r, aluminum luggage,windshield,handguards,heated grips,Clarke tank,high frt fender,led running lights,folding shifter, wide pegs,12v outlets,headlight kill switch,voltmeter,stainless header,2nd brakelight,GPS/phone mount
    Jul 2013
    Mt Pleasant, NC
    188
    Ok, searched for the Ram Mounts, found them on Amazon for a deal, so here is my set up. Remember i used to use this on my fishing boat, so its a chart plotter. On the other hand, I have excellent info on the "Hot Spots" for my local lakes and all the east coast marine boating information. I couldn't figure why my speed was off until I got to playing with the settings and I was in knots not mph gps3.jpeggps2.jpeggps1.jpeg
  1. Quick Help
    By BC4Lyphe in forum Technical Help
    Last Post: 03-28-2013, 11:23 AM
  2. Quick and easy I phone mount!
    By Gabriellapua in forum Performance and Customization
    Last Post: 03-13-2013, 11:15 AM
  3. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 10:25 PM
  4. Battery quick to die?
    Last Post: 10-02-2012, 07:45 PM
  5. Quick ride
    By xdac in forum Trails, Off-road, and Adventure Riding
    Last Post: 11-10-2011, 01:34 PM
