TW's ugly half chinese step sister
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree7Likes
Thread: TW's ugly half chinese step sister
    Apr 2011
    Martinsville Indiana
    2,089
    Nov 2011
    norcal nutjob
    3,327
    328 lbs?? that baby needs a good diet.
    Pleasanton, CA
    5,747
    Hhhmmmm . . . I wonder if that rear disc brake could be made to fit on a TW?
    IzakGt and Bduff007 like this.
    Member like2wlz's Avatar
    Oct 2013
    89
    These sell for $2199 around here. I briefly thought about buying one until I saw the weight. My old DR350 was 20# less wet, and I thought that was too heavy.
    jbfla likes this.
    Senior Member Ice_Man's Avatar
    Sep 2013
    Western, MA
    193
    Thinking the exact same thing
    Desert, SoCal
    7,369
    Looks suspiciously Zongshen-ish. Which makes it XT-ish, with a 15 inch rear wheel. I seriously doubt it even comes close to weighing 300 pounds.
    Leave it to the Chinese to shoot themselves in the foot by exaggerating weight to the plus side.
    Mongol Pete likes this.
    Senior Member HappyHiker's Avatar
    Aug 2013
    Lakewood, CO
    323
    Found these specs:
    These are available in gloss black white and orange. We have white in stock currently! High quality construction inverted and adjustable front forks front and rear disc brakes electric and kick start with an air cooled single cylinder 15 horse power 200cc engine! Top speed is approx 75 miles per hour. Black white or orange available Engine Type: 199cc 4 Stroke Air Cooled Carburetor: 26mm Bore Stroke: 66mm x 58.2mm Horsepower: 15 @ 8000RMP Start Mode: Kick Start / Electric Start Transmission: 1 Down 4 Up 5-Speed Manual Frame: Steel L x W x H: 81 x 30.5 x 44 Front Suspension: Inverted Rebound/Compression Adjustable Rear Suspension: Spring Shock Brakes: Front/Rear Disc Wheels: STREET: 17 /17 Seat Height: 32.5 Weight: 328 lbs Ground Clearance: 8 Wheelbase: 48 Covered Parts Description Covered Period Motor Engine Transmission 1 Year (Unlimited Miles) Mechanical Components Carburetor 1 Year (Unlimited Miles) Electrical Harness CDI Inst. Cluster 1 Year (Unlimited Miles) Battery (when purchased with new unit) Battery 30 Days (Unlimited Miles) Suspension Shocks Forks 6 Months (Unlimited Miles) Brake Caliper 1 Year (Unlimited Miles) Exhaust Header pipe Muffler 1 Year (Unlimited Miles) Clutch CVT/Manual Clutch 90 Days (Unlimited Miles)
    Electric and kickstart, air cooled, 15 HP, carb, tach, speedo with dual disc brakes. No mention of fuel capacity. Not too shabby. Have to wonder about the quality though...
    Desert, SoCal
    7,369
    Hard telling, but SSR is one of the better importers. Or at least one of the more longstanding ones.
    The way that stuff works is that tons of the same bikes are made at different quality levels all over China, often from the same plant. Various importers spec their own level of cheesiness then slap their own brand names on what are essentially identical bikes. The fly-by-night outfits spec the low end, don't submit them for the proper paperwork which allows you to register them, etc. Then theydump them on unsuspecting losers, then close shop or change names, lather, rinse, repeat. The goodn's spec the upper end of the same bikes and are more likely to be around to back it up tomorrow.
    The trick is knowing which of the junk, isn't. Some of it is actually quite decent. Spuds 60,000 mile Zong comes to mind.
    Senior Member Polarpilot's Avatar
    Iqaluit Nunavut Canada
    422
    Looks very much like a Chinese bike marketed as a "konkor". Here in Canada
    Member birdmove's Avatar
    Keaau, Hawaii
    77
    It is also sold as the Qlink (pronounced as Q-Link, and not Klink) XP200 and XF200. Motorcycle,com tested one here:
    2009 QLINK XF200 Review - Motorcycle.com
    A guy known as Spudrider on a bunch of forums (mychinamoto.com, advrider.com, etc) is still riding a Chinese 200cc dual sport and is over 60,000 miles so far. He rebuilt the top end twice I believe. His is a Zongchen.
    Jon
    Keaau, Hawaii
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. Cheap Chinese Hand Guards Review
    By kdick91 in forum Performance and Customization
    Last Post: 07-09-2013, 09:31 AM
  3. Half Link
    By elime in forum Test Forum
    Last Post: 10-22-2012, 09:23 AM
  4. Half a$$-DV trip report
    By bikerjosh in forum Trails, Off-road, and Adventure Riding
    Last Post: 11-08-2011, 09:35 PM
  5. Chinese Copy of TW
    By Polar_Pilot in forum General Discussion
    Last Post: 11-05-2010, 09:01 PM
beeg dual disc
beeg sister
beeg sister page
beeg step chinese
beeg step sister
beeg step sister black
beeg step sister page
beeg stepsister
sister beeg
step sister beeg
stepsister beeg
stepsisterbeeg
