Assembling a tw200
Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By GaryL
  • 2 Post By goldenhtr
Thread: Assembling a tw200
    Junior Member Big Bubba's Avatar
    Dec 2013
    Assembling a tw200
    Ok, I got a 1993 tw200 from a buddy that was taken down completely. He rebuilt the engine for it and repainted the bike, but never had the time to put it back together and told me I could have it. It won't be hard reassebling it, but I would like to have a manual or some schematics to look at in the case that I run into an assembly problem. Does anyone know where I can get that? any help is greatly appreciated.
    Frosty Hollow
    13,094
    In the Technical section there is a sub-section called Technical write ups at the top. In this section is downloadable manuals. Here: https://tw200forum.com/forum/technica...r-manuals.html
    I've had mine tore apart, and the electrical wiring harness was probably the most difficult to re-install. Luckily, I had labeled everything and didn't need the manual. Putting it back together will be like a puzzle, sort of easy.
    Nov 2011
    norcal nutjob
    3,327
    welcome to the forum.
    there's lots you can do to these little bikes to make them your own, enjoy the madness!
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,092
    I call that a big score and a very good pal! Rebuilt engine and a freshly painted frame with all the parts to be up and running for free, WOW!
    Just my opinion here but I think the assembly would be a breeze if you had another TW in your garage that you could look over and compare while you are getting everything put back together. If you lived close to me I would be happy to allow you access to mine and with the tank and seat off it would be pretty easy to just look at mine and do the same for yours.
    goldenhtr likes this.
    1987 Yamaha BW350 Big Wheel
    Stanwood,Wa
    1,898
    +1 GaryL If only people would fill out their profile and let others know where they are from, I think there would be alot more offers like yours. Good for you GaryL.
    Mel and TW-Brian like this.
    Dec 2013
    Thanks ya'll for the help
    Senior Member 50short's Avatar
    Aug 2013
    Excelsior, MN
    287
    +1 Gary
    On that note, if you want me to take pictures of a certain part of the bike so you can see routing or position just let me know! Happy to post'em right here for you. I'm sure the other members would too.
  1. Assembling a modified TW125 engine
    By btdc in forum Performance and Customization
    Last Post: 01-29-2011, 10:33 AM
