Replacement levers
Results 1 to 5 of 5
Like Tree8Likes
  • 3 Post By joeband
  • 1 Post By r80rt
  • 3 Post By elime
  • 1 Post By admiral
Thread: Replacement levers
    Senior Member williamemack's Avatar
    Apr 2013
    winters in Sudbury, MA, summer on Squam Lake, NH
    363
    Replacement levers
    After reading a recent thread about breaking our TWs levers, I got wondering if there are better levers out there that we can swap out for the OEMs. What aftermarket levers do you use and why ?
    Nov 2011
    norcal nutjob
    3,327
    with my bark busters, i've never broken a lever.
    r80rt, tcepilot and THE MENACE like this.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    I agree with Joe, I carry an extra lever but with my hand guards I probably don't need to. If I didn't have hand guards I'd use the Moose shorty levers, they don't stick out as far so there is a lesser chance of breaking them.
    littletommy likes this.
    6,984
    It is better to break the lever than what it mounts on.
    Some people even drill a hole in the lever to make a weak spot to make sure the lever is what breaks.
    r80rt, williamemack and tcepilot like this.
    Frosty Hollow
    13,088
    Limp back home mode.
    I broke my clutch lever one time. While sitting out "there", I was thinking "now what".
    Though I don't recommend this for normal riding, I was able to shift without the clutch and made it back to the truck. When I got to a spot where I needed to be in neutral, I just turned the engine off, stopped, turned the key back on without starting, found neutral, started the engine back up, took aim of the direction I needed to head, dropped in 1st and off I went. I think you may get the idea. Main point is you can probably limp back without the lever if need be.
    Brake lever is even easier, though I've not broken this one yet. Rear brake is nice to have eh!
    joeband likes this.
  1. Replies: 11
    Last Post: 04-15-2013, 10:24 AM
  2. Short levers
    By rbm in forum Performance and Customization
    Last Post: 04-07-2013, 10:46 AM
  3. Clutch and Brake Levers
    By marcuskilpatrick in forum Technical Help
    Last Post: 09-10-2012, 11:10 AM
  4. Aftermarket Control Levers
    By Knightowl in forum Performance and Customization
    Last Post: 04-01-2012, 05:21 PM
  5. Best front brake + clutch levers?
    By TW200_CA in forum Technical Help
    Last Post: 09-16-2011, 03:39 PM
replacement shifter lever for tw200
tw200 brake lever
tw200 shift lever replacement how to
