Tire Pressure Question??
Results 1 to 3 of 3
    Member Mystic Explorer's Avatar
    Aug 2013
    51
    I live next to a million acres of Arizona riding area. I have to ride city streets for about 4 mies to get off road.
    The desert here has rocks the size of baseballs and if I ride with factory air pressure it about throws me off the bike.
    What pressure can I go to and still ride OK at 45mph on the streets
    Thanks everyone
    Mystic
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    The best way to go about this would be to carry a small tire pump and a tire gauge. Lower your pressure to about 12-15 psi when you reach your destination....ride......then, before leaving on the pavement ,inflate to regular tire pressure.....20 psi front & 25 psi rear,approx.. I'm sure you "could" ride on the pavement @ 45 mph with 15 psi,but............ .
    Hailey, ID
    3,376
    Quote Originally Posted by Mystic Explorer View Post
    What pressure can I go to and still ride OK at 45mph on the streets.....
    I ride 5 miles at 60mph all the time with 12 front and 14 rear before getting to the dirt and I've never had a problem. It is pretty much straight though, if I had a twisty road I'd want maybe 16/16.
    If I am going further than 4-5 miles on slab I would go up to at least 18/18, but that is very rare for me....I would usually trailer the bike in that case. This is with stock rear and Kenda 270 front.
    I do notice a little more squirrellyness, but it's not a big deal on a straight road. Tire wear pattern seems to be perfectly normal at 6500 miles....these carcasses are pretty stiff. The only time I've ever used 22//25 is when two up on the pavement....the tires are like rocks at that pressure.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Tire Pressure....
    By bsullivan161 in forum General Discussion
    Last Post: 06-30-2013, 12:34 PM
  2. Tire pressure
    By Drifter in forum Technical Help
    Last Post: 10-10-2012, 05:52 PM
  3. tire pressure
    By ridgeline in forum General Discussion
    Last Post: 09-18-2012, 07:27 PM
  4. Tire Pressure On The Fly
    By thumper in forum General Discussion
    Last Post: 11-22-2010, 01:02 PM
  5. TIRE PRESSURE
    By Turtle Chaser in forum General Discussion
    Last Post: 09-24-2010, 07:08 PM
