TW200 for tall people
Results 1 to 10 of 11
    Senior Member dhoenisch's Avatar
    Chicagoland, IL
    512
    Hey all, I was trying to search the archives, but I can't find them. Anyhow, I'm 6'2", and after riding my Honda GL500 all week, I get back on the TW200, and I seriously need to do something about both the handlebars and the mirrors. There were posts on both handlebar risers, and something that lifts the mirrors up and over a couple of inches. I can get the handlebar risers on eBay, unless there is a better place to get them, but for the life of me, I can't find those things for the mirrors. Can anyone shed some light on this?
    Also, I think I need to upgrade the sprockets on the TW so that first gear isn't so worthless on the street, but I know there are posts galore about gear sizes and all.
    Thanks all,
    Dan
    2009 Yamaha TW200
    1996 Yamaha Virago 1100
    Member JerryT's Avatar
    crossville, tn
    86
    Can't help you with mirrors, but I use my TW mostly on the street, but still like to hit the trails at times. I changed the front sprocket to a 15 tooth and kept the stock 50 on the rear. This works real good for me. Gearing is pretty much a person feeling for what you want to do with the bike.
    Member n8bone's Avatar
    corn desert, IL
    46
    Quote Originally Posted by dhoenisch View Post
    It's not a whole lot taller but the Stearns/Wal-Mart pad was a great addition for me. Changing to 15 in the front is almost the same as putting a 47 on the back, if I remember correctly. (calculator link) In either case, WAY better for street riding and no chain mod required.
    edited to add: I found a cached thread where these EMGO mirrors were recommended.
    Hidden Content : KLR pegs, 47t sprocket, cyclerack, Bridgestone 203/204, D.I.D. o-ring chain, Jimbo shield
    Hidden Content : gone to a new home. it was my first...had it for 14 years. miss it sometimes.
    Junior Member Calgarystevens's Avatar
    Calgary
    20
    This auction might be ended now, but: http://cgi.ebay.ca/10mm-Motorcycle-M...QQcmdZViewItem
    that'll give you a starting point. As far as sprockets go, I switched to an o-ring chain and 15/47 sprockets and it is sweet. Got my combo from Lytle Racing (google em). Feels like a new bike around town and no mirror shake at highway speed anymore. Quite nice. :-)
    1998 Yamaha TW 200
    Computer addicts never die, they just go offline
    Chicagoland, IL
    512
    Quote Originally Posted by CalgaryStevens View Post
    Yup, those would be them. Hope to find some in chrome, but if not, these will do perfectly.
    I'll look into the gear ratios you have. I do plan to take this bike off-road on the trips I take to West Virginia, so I could always put the stock gears/chain back on before I leave on those trips.
    Thanks all,
    Dan
    2009 Yamaha TW200
    Double Walmart seat pads and handlebars 2 inches taller will make a world of difference in fit. Aluminum handlebars with some good grips will solve a lot of vibration problems. There are adapters for the yamaha's left-hand threaded mirrors so any universal right hand mirrors with the same size shaft will fit. There are anti-vibration mirror mounts sold for KLRs that will raise the mirrors a bit and clear up the images in those Emgo long-shaft mirrors. You'll need the adapters to run the anti-vibe mounts.
    Chicagoland, IL
    512
    I found those mirror risers/extenders in Chrome on eBay, so those are on the way, and on pay day, I will order the handlebar risers (little on the broke side these days).
    I guess I should have made it clear, sorry I didn't, that the seat height doesn't bother me at all. In fact, I like where it's at with the single Walmart seat cover and all that I have on it (my cruiser sits lower, so that's probably why I like the seat height where it's at). For me, it is more that I would like the handlebars a little higher, and even more so, I want the mirrors to see more than just my arms. This morning, I was trying to get them to twist up more than they could, and I was afraid I'd break them. I think raising them up and out as much as the risers/extenders are supposed to do will work out great, especially once I get the handlebar risers. I will look into aluminum handlebars, but I'll see how both types of risers will work out first.
    Dan
    2009 Yamaha TW200
    Member Idaho04's Avatar
    46
    I would do the bar risers or high ATV bars and then worry about the mirrors. One step at a time I found was the right pace so i didn't undo an advantage or go too far with my mods. I think that the higher bars was by far the BEST mod Ive done to the TW. The 15 tooth front sprocket is really nice as well. Do the sprocket and bars and then see what you need. The front sprocket is a real pain since you have to take the side cover off but not hard at all. i would just tip the bike to the side so the oil drains over to change the sprocket, but this is a good time for an oil change as well.
    Good luck
    Idaho 04
    Senior Member Two Shoes's Avatar
    High Desert, California
    110
    I'm 6'3" 160Lbs 34" inseam and only "TALL" sized long sleeve shirts come close to fitting my extra long arms.
    Still, I have put over 10k miles on my TW with my gangly ass riding it in stock form and have no complaints about fit.
    Then again, I did "upgrade" from a chopped out Ruckus
    This isn't mine but almost identical.
    Junior Member marcortez's Avatar
    Aug 2010
    6
    Can someone please point me to a vendor of these higher handlebars please.
    Edit:.....I found some thanks
  1. Riding with 2 people
    By chevyy1212 in forum General Discussion
    Last Post: 12-20-2011, 10:31 AM
  2. Proof of Tall Tale!
    By Purple People Eater in forum Off-Topic
    Last Post: 11-04-2011, 05:53 PM
  3. Why do people stare at us?
    By Hendragster in forum General Discussion
    Last Post: 12-01-2010, 09:22 AM
  4. Why are people staring at me?
    By glas482 in forum General Discussion
    Last Post: 09-25-2010, 06:44 AM
  5. tall people
    By tkrrox in forum Technical Help
    Last Post: 08-20-2010, 07:04 PM
higher handle bar tw200
tall guy tw200 mods
tall guys on tw200
tw 200 for big guys
tw 200 higher seat
tw200 forum
tw200 tall person
tw200 tall seat
tw200 taller
tw200 taller seat
why did they not make a bigger version of the tw 200
yamaha tw200 for tall men
