Rear tire replacement question
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree8Likes
Thread: Rear tire replacement question
    Senior Member cptrout's Avatar
    S. Torrance (So. Cal.)
    353
    Going to be replacing my rear tire as soon as it arrives and I have one question. After I replace the tire what about balancing the tire. Is that a concern, do I need to worry about that? If yes, how do I go about balancing it.? Thanks for the help.
    UPDATE
    The tire is mounted!!! I have a local indie shop that I never used before, read bad reviews, but I stopped in and talked to the guy. I don't know why all the bad reviews. He said $25 to mount/balance the new tire. $25? That couldn't be. So I pulled the rear wheel and took it into him and he did the job in the 3-hour window i asked for. I was impressed, I bought his lunch that day.
    The only down side is I'm no longer flat-footed at a stop light, that's how worn my tire was.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    I used RideOn tire sealant, it has balancing properties as well. I think this is the easiest option.
    littletommy and n2o2diver like this.
    Senior Member silverwing's Avatar
    Herman, MN
    320
    harbor freight has a motorcycle tire balancing stand, works great
    Frosty Hollow
    13,082
    You may not need to balance it at all, assuming you're doing the work at home and not at a motorcycle shop. I replaced my rear tire at home this past summer and it did not need to balanced. Nor was there any balance weights when the stock tire was on.
    If it does need to be balanced, you'll have to weigh the cost of buying the equipment and products as mentioned above, versus taking the tire to a m/c shop and having them balance it for you. Both products listed above are good alternatives for the DIY mechanic. I like the Ride On, as it suppose to balance the tire and help prevent flats. Good luck.
    Just put the axle through the hub and support the ends on blocks or something--accurate enough for our purposes. Mark the low spot on the rim and tire. Deflate the tire and slide the tire around the rim. With a few patient tries I can usually balance a motorcycle tire without weights, or at least reduce the weight needed. There are weights available with a slot in them that slide over the spoke, and centrifugal force holds them tight when you push them down on the nipple. Simple and effective.
    Ride-On is in every tire I own. It is that good.
    littletommy likes this.
    Hailey, ID
    3,376
    ++1!
    6,800 miles exploring old mine areas without a flat.....
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Hello qwerty,great info as usual.
    1,110
    I see Amazon has the 32oz RideOn for $20, free shipping.
    *EDIT* My mistake. This is the ATV formula....not for motorcycles.
    Jun 2011
    Dothan, AL
    1,715
    I used ride-on as well.
    I notice the front smoothed right out and the bars don't shake!
    Havent had had a flat yet either.
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member BillMichaels's Avatar
    SF Bay Area
    277
    +1 on H.F. balancer. I have some football shaped lead weights that I've drilled larger to the spoke width (can't remember size). Then I did a hot dog bun cut length wise with a hack saw. Stick a dab of silicone on the spoke, vise grip the weight on, and you're good to go. Hardest part is finding lead weights here in Kalifornia.
    MTLHead and bananachunks like this.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
  1. Replacement rear tubes
    By 29andSingle in forum General Discussion
    Last Post: 12-27-2013, 02:41 AM
  2. Tire Pressure Question??
    By Mystic Explorer in forum General Discussion
    Last Post: 12-17-2013, 07:24 AM
  3. Head Warpage Check and Front Tire question
    By cowboyjeff in forum Technical Help
    Last Post: 11-18-2013, 04:26 AM
  4. Duro Rear Tire Trim Question
    By maineidyl in forum Performance and Customization
    Last Post: 09-11-2011, 08:15 PM
  5. Nail in Tire question
    By thumper in forum General Discussion
    Last Post: 12-13-2010, 02:33 AM
tw tire replacement
