Would this SwingArm Stand work with the TW?
Results 1 to 10 of 14
Like Tree1Likes
Thread: Would this SwingArm Stand work with the TW?
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    Motorcycle Swingarm Rear Stand
    Anybody use a swingarm stand like this with their TW?
    Thanks for any info...
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    I don't see why it wouldn't work.
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    " can be adjusted from 10-1/4" to 13-3/8" to easily accommodate different motorcycle widths."
    TW is 12.25 center to center so it should work.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    I was looking at this very model at HF. Let us know how it works!.
    Jan 2014
    New Jersey
    592
    I came up with 11.5" center to center...
    I will measure again tomorrow
    1,110
    I've got one and it does work. The only issue is the lower chain guard (bolted to the bottom of the swingarm by the rear sprocket) blocks the stand from cradling the swing arm like it should. I just lift the bike with the cradle as close to the guard as I can get it but if I take the guard off to give me more room it would probably be safer. If that doesn't make sense I can go out and snap a quick pic. Bottom line is that it works and is very handy.
    Jan 2014
    New Jersey
    592
    Funny you brought that up...I was looking at that plastic piece tonight. But then I figured I could put the braces in front of it?
    Pics would be great if you can
    Thanks!
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Buy two, get one fork adaptor atachment, then you can lift the bike completely off the floor.
    Stephen S.
    '07 TW200:
    1,110
    On a bike with the stock inner fender, the handle of the stand hits and you can't get it far enough under the bike to get the cradle to clear that plastic guard. I had a problem anyway....your results may differ.
    I made a smaller tail light bracket on my '95 so the handle doesn't hit. There's no problem using this stand on it.
    The rear tire is about 1 1/2" off the ground when the bike is on the stand.
    Thanks for getting me off my butt. I see the chain needs lube. It's an o-ring but the salt is making things rusty. It'll be easy now that it's on the stand.
    maddawgj likes this.
    Jan 2014
    New Jersey
    592
    Thanks for the pics...Now I se what you meen. I have the stock inner rear fender so I will probably have to take that little guard off
    But that shouldnt be a big deal
  1. Stand or Jack?
    By nfpgasmask in forum Technical Help
    Last Post: 09-25-2012, 09:52 PM
  2. Kick stand bolt and.....
    By Revolverman in forum Technical Help
    Last Post: 05-30-2012, 09:02 PM
  3. WTB...kick stand
    By rastaman in forum TW200 Classifieds
    Last Post: 08-14-2011, 11:04 PM
  4. TW - What's it stand for?
    By Rohnsman in forum General Discussion
    Last Post: 06-21-2011, 11:14 PM
  5. Kick Stand Bolt
    By ATXthumper in forum Technical Help
    Last Post: 09-05-2010, 03:56 PM
swingarm
tw200 stand
