Will this headlight bulb work?
Results 1 to 4 of 4
    Senior Member cptrout's Avatar
    S. Torrance (So. Cal.)
    353
    My headlight bulb on my '08 finally called it quits. I purchased this Silverstar bulb and before I install it I want to make sure it's the right one. The last thing I want to do is damage my bike in the near or long-term. Thanks for your input.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    That should work just fine. Beware of decreased life with the Silverstar, I installed them in my Honda CR-V a while back and they wouldn't last more than a few months. I did get free replacements from Sylvanis for the burned out bulbs but in the end decided to go back to standard bulbs for longer life.
    18,853
    Silvertar is an upgrade that will give much better light at expense of shorter service life. Happily have them in my van less than 200 hrs total, but am dissapointed to hear of short life for rbm. The light seems to give much better illumination than stock hi beam.
    If I had it home in my paws I would go ahead and install it and justify expense as safety related "They can see me better" and hope for long life.
    Aug 2011
    Cayce, SC
    3,109
    I've had one in mine for over a year now. It is a slightly brighter bulb than stock but not a huge difference. When it goes out I will be putting a piaa bulb in it. I have them in my other two bikes and like the color and brightness. They are like $45 in stores but you can find them for around $30 on ebay.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
  1. Think this headlight would work?
    By Deldog in forum Technical Help
    Last Post: 05-16-2013, 04:38 PM
  2. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
  3. Quest for a brighter headlight with stock fixture / DOT bulb
    By praeses in forum Performance and Customization
    Last Post: 08-12-2011, 10:14 AM
  4. H4 bulb question / What headlight setup do you have
    By chines75 in forum Technical Help
    Last Post: 05-24-2011, 04:02 AM
  5. Headlight bulb question
    By darnold87 in forum Technical Help
    Last Post: 03-25-2011, 07:22 PM
