More ccs on the T-dub
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By plumbstraight
Thread: More ccs on the T-dub
    Junior Member yawabala's Avatar
    Aug 2012
    Nairobi, Kenya
    22
    Exclamation More ccs on the T-dub
    Hey guys,
    Here's one,just about how many cases of success have there been in fixing bigger engines on your t-dubs?I've been floating the idea, but I kynda freak out at the thought of it not working.....
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,718
    If you need to outrun lions, get a faster bike. These little bikes are great for anything but speed.
    MTLHead likes this.
    Senior Member Borneo's Avatar
    Feb 2014
    6,368
    Among other things, you will have to account for the countershaft issue. Engine swap: xt250 - Yamaha TW200 Trailway Discussion Forum
    my blog Hidden Content
    Tdub2 is 267cc and peak torque is almost double stock, with significantly more area under the curve. Better have a fat wallet. The EFI alone was almost $900.
    Displacement alone won't make much difference as the air flow limits of a mild cam and small carb choke the stock displacement. If you have a few hundred dollars to spend, a mild cam and matching springs will provide the most bang for the bolt-in buck. Follow that up with a bigger carb and custom airbox with a free-flowing filter (low buck trick would be a TT-R 230 carb) and you'll notice a big difference in power without much compromise in efficiency or durability. Aftermarket exhaust will tend to add peak power, but at some cost of low/midrange and torque curve width, which can be a problem with the wide ratios of the top gears of stock transmission. Exhaust would be the last thing I'd change if I wanted more power--the stocker is actually pretty good, other than being heavy.
