Stop Lever Rattles
Results 1 to 5 of 5
Like Tree4Likes
  • 2 Post By Fred
  • 1 Post By rurlndum
Thread: Stop Lever Rattles
    18,813
    Stop Lever Rattles
    I don't like minor rattling of brake and clutch levers metal on metal contact so I use very thin nylon shims between lever and perch to quit things down, allows me to concentrate on valve noise and the famous front end clunk What I call the seven-cent psuedo-farkle is simple nylon shim from Lowe's big enough to fit over 8mm lever pivot shaft. Think they are about 3/8 id x 5/8 od x 1/32 inch. Allows good lever action w/o annoying wobble.
    Leben and r80rt like this.
    Senior Member Borneo's Avatar
    Feb 2014
    6,368
    That's a great idea Fred. Seems a bit sane against tonight's backdrop of pant packs and apocalyptic dirt biking.
    my blog Hidden Content
    Senior Member rurlndum's Avatar
    Jun 2013
    463
    As I understand this you are annoyed with the noise the levers make. Try being married to a banjo player.
    Fred likes this.
    18,813
    It is just a very simple thing but wobbles and rattles and banging represents inefficiencies and wear, offends my engineering sensitivities. Blame it on reading too much Robert Heinlein science fiction in my impressionable youth. Just thought I'ld mention this as an alternative to overtightening perch pivots to crush away free play which can result in a grabby lever action.
    you should see me packing and rattleproofing my van on off-road adventures...Runindum, how do you pack a banjo player?
    Jun 2013
    463
    Rurlndum, how do you pack a banjo player?
    Reluctantly.
    Borneo likes this.
  1. throttle grip stop
    By Tuber in forum Performance and Customization
    Last Post: 04-15-2014, 11:03 AM
  2. Stop-n-Go traffic advice?
    By decade03 in forum General Discussion
    Last Post: 10-23-2012, 12:35 PM
  3. Removing front stop switch
    By Guitarman in forum Technical Help
    Last Post: 05-02-2012, 06:11 PM
  4. stop lights
    By chevyluver in forum General Discussion
    Last Post: 08-02-2011, 02:12 PM
  5. Kickstand rattles
    By n2o2diver in forum Technical Help
    Last Post: 06-15-2011, 09:47 PM
front end rattles on 2014 tw200
