Cartoon of How CV Carburator Meters Air/Fuel Throughout RPM
Results 1 to 6 of 6
Like Tree10Likes
  • 8 Post By Fred
  • 2 Post By Leisure Time Larry
Thread: Cartoon of How CV Carburator Meters Air/Fuel Throughout RPM
    18,413
    They say a picture is worth a thousand words. A good cartoon can be even better
    As you can see various circuits contribute additional fuel with increasing rpm to the overall supply to the engine. I find it helpful to review this occasionally.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,381
    Hi Fred,
    I thought cartoons were supposed to be funny!
    ...and where's the "coaster" circuit?
    jb
    Jul 2012
    Wet-ern Washington
    1,403
    This is a good one. I've posted it many times when peeps are having carb trouble and trying to learn. Worth a sticky!
    littletommy and Fred like this.
    - Leisure Time Larry -
    2004 TW200, 13-54 gearing, Shinko 241, Race Tech Emulators, Procycle front springs, Works Performance rear shock, Emgo handguards, Luckybike mirror risers, Ken Sean DS foldable mirrors, 30mm Tusk bar risers, Seat Concepts, Kick Starter kit, Plasti-dip camo coat, Cycle Pumps, Ricochet Skid Plate, flood and spot LED pod lights, Sena, Garmin etrex 20 GPS, IMS 313114folding shifter
    Senior Member Welder's Avatar
    May 2015
    PNW
    113
    Is that accurate? I thought vacuum would cause the pilot jet to feed fuel at ALL throttle positions (?).
    FL. GA, NC
    2,381
    Quote Originally Posted by Welder View Post
    You thought right. It does, just not as much.
    jb
    18,413
    I can't thank Irppcer enough for originally posting this video long ago. While not perhaps perfect it does show the interplay happening. Helps when trying to explain that indeed the pilot jet and pilot mixture screw contribute at higher rpms for those who occasionally insist on arguing the contrary.
  1. Fuel Leak at inlet elbow of carburator
    By theedge900 in forum Technical Help
    Last Post: 07-11-2014, 05:28 PM
  2. carburator throttle linkage
    By HercJerk in forum Technical Help
    Last Post: 03-30-2013, 08:49 PM
  3. Carburator float towers
    By Cagiva in forum Technical Help
    Last Post: 11-03-2012, 11:17 AM
  4. Cartoon
    By srs713 in forum Off-Topic
    Last Post: 03-18-2012, 12:43 PM
  5. carburator upgrade
    By neverseemefall in forum Test Forum
    Last Post: 10-25-2010, 01:28 AM
