Some help to ID Vintage First Aid kit, I think a Military kit?
Results 1 to 9 of 9
Like Tree8Likes
  • 2 Post By pred
  • 2 Post By Fred
  • 2 Post By Dryden-Tdub
Thread: Some help to ID Vintage First Aid kit, I think a Military kit?
    Senior Member pred's Avatar
    Mar 2016
    Philadelphia and Pittsburgh pa
    545
    I found this today at a local Flea and thought it was quite odd and wanted to figure out where it was from,
    There is no ID on the metal box itself that Ive found,
    As you can see, It sleeves into the box and has two large clasps on the top/side,
    The top with handle is cast steel and the entire assembly weighs about 12 pounds,
    Ive seen tons of old first aid kits, But not one like this,
    Any ideas?
    Thanks
    May 2014
    Yooper, MI
    1,510
    Definitely not US Military.
    18,813
    Neat, well equipped. Sort of resembles some of the old MSA mine first aid kits I would see underground. Any discernible identification on the logos of the individual boxes?
    Mar 2016
    545
    The first aid items were made by MSA in Pittsburgh,
    Seems odd to be in a mine due to weight,
    This one really puzzles me and I hope to find another like it for reference on the web,
    The bullet proof construction would lend to a jeep or vehicle mounted item,
    BUT I could be 100% wrong as well,
    Ill spend some time tomorrow eve looking it it under higher power and see if I can find anything anywhere on it,
    Peter B
    Apr 2014
    Dryden NY
    6,342
    Quote Originally Posted by pred View Post
    Peter B
    KIT, FIRST AID, MOTOR VEHICLE, 12-Unit (item #97773)
    (submitted by Alain Batens)
    (Kit, First Aid, Motor Vehicle, 12-Unit, Item #97773 – period 1942-1944 – from the collection of Alain Batens)
    from L to R: open view of Medical Kit (the cover contains a label with full kit contents, directions for use of medical items, official nomenclature, and name of manufacturer (or distributor)
    Contents of 12-Unit Motor Vehicle First-Aid Kit
    (Period 1942-1944)
    NOTE: This kit packed in a small transportable metal case is usually distributed, one per every fourth vehicle (e.g. jeep-weapon carrier-cargo truck, etc. excluding armored vehicles ) . In ¼ Ton Trucks it is usually stashed away in a holding bracket, centrally located under the vehicle’s dashboard . The metal case is of rectangular shape, and opens on either side w/clips (2 + hinge or 4) or on one side only with 2 clips, while the other side is foreseen with a single narrow hinge . It has only one carrying handle . The case is painted olive drab, while the lid shows a white FIRST AID in the upper part, a red caduceus w/ U.S. ARMY + MEDICAL DEPARTMENT on a white circular background in the center part, and a white FOR EMERGENCY USE ONLY in the lower part . The cover has a complete label inside with nomenclature, directions for use, and list of contents .
    CONTENTS:
    1 X Bandage, Gauze, White, 4-in x 6 yds, w/2 Large Safety Pins (item #92015)
    1 X Bandage, Gauze, Compress, White, 4-in x 4-in (item #92002)
    1 X Bandage, Gauze, Compress, White, 2-in x 2-in (item #92004)
    1 X Bandage, Gauze, Adhesive, White, 1-in x 3-in (item #92000)
    1 X Bandage, Triangular, Compressed, White (item #92040)
    2 X Set, Burn, Injury, w/ Sulfadiazine Ointment & Applicator (item #91042)
    1 X Set, Eye, Dressing (item #91095)
    10 X Swab, Iodine (in single box) (item #91122)
    10 X Inhalants, Ammonia (in single box) (item #91025)
    1 X Set, Tourniquet-Scissors-Forceps (item #93797)
    1 X Packet, Pin, Safety, Medium, Size 2 (item #78780)
    6 X Packet, Sulfanilamide, each containing 5 grams Crystalline Sulfanilamide (sterile, individual, double-wrapped, paper envelope, w/ shaker top) (item #91211)
    NOTE: Morphine Tartrate Syrettes of ½ Grain may be added to the kit only upon direction of the C.O. and when military circumstances indicate its need ! (this is item #91157)
    Later modifications (course 1944 + early 1945) entail replacement of White bandage material by Field Brown (with change of item numbers) and increase from 5 > 7 digits, after June 1944)
    It should be noted that contents sometimes differ as per supplier and, that they also evolve because of the continuous development of medicine in general. Complete kit is Item #97773, while Container is Item #97774.
    Above kit was manufactured by MINE SAFETY APPLIANCES Co., Pittsburgh, PA, 23 June 1944
    FM 21-11 First Aid For Soldiers April 7, 1943 states … this kit is supplied to motor vehicles, usually 1 to every fourth vehicle
    KIT, FIRST AID, MOTOR VEHICLE, 12-Unit (Type D)
    (Kit, First Aid, Motor Vehicle, 12-Unit, Type D - period uncertain – from the collection of Alain Batens)
    Closed view of subject Medical Kit (drawer type)
    (Kit, First Aid, Motor Vehicle, 12-Unit, Type D – period uncertain – from the collection of Alain Batens)
    From L to R: open view of Medical Kit (drawer type, open showing inner box w/contents, the protection cover contains a label with full contents, directions for use, nomenclature and name of manufacturer, outer box )
    Contents of 12-Unit Type D Motor Vehicle First-Aid Kit
    (Period 1940-1942) ?
    NOTE:: Is this kit dating from WW1, WW2 or from the period between the World Wars ? Who can tell ?
    The kit is packed in a small rectangular transportable, rather heavy, metal case, distributed among every fourth vehicle (excluding armored types) . It looks like a drawer, since it slides open after unhooking the 2 clips on either side . When drawing open the kit, there’s a small metal ring allowing to pull open a protective cover, which then gives acces to the medical contents . This first aid kit has only one carrying handle . The case is painted in a brown drab shade, and used to have the full-color M-S-A emblem + markings on the front side (these decals have now almost completely gone), it also bears a white number 216 on the other side . Next to the cover (front part drawer) is an indication with THIS SIDE UP . The cover has a complete label inside with nomenclature, directions for use, and list of contents .
    CONTENTS:
    1 X Bandage, Gauze, Compress, 1-in x 3 ½ -in (item #92000) for covering large wounds & burns
    2 X Bandage, Gauze, Compress, 2-in x 2-in (item #92004)for covering medium size wounds & burns
    2 X Compress, Mercuro (item unknown) for covering small wounds
    1 X Swab, Mercurochrome (item unknown) for sterilizing wounds
    10 X Inhalants, Ammonia (in single box) (item #91025) for fainting & shock treating
    1 X Bandage, Triangular, Compressed, White, 36-in x 36-in x 50-in (item #92040) for slings & covering dressings
    1 X Bandage, Gauze, Compress, White, 4-in x 4-in (item #92002) for sprains & general bandaging
    1 X Unguentine – for burns (item unknown)
    1 X Tourniquet & Forceps (item unknown) for stopping arterial bleeding & removing splinters
    NOTE:: Later modifications probably entailed replacements of certain items by others . It is not known when this kind of first aid kits (D=drawer type) was replaced by the standardized 12-Unit model … if anybody can fill-in the gap, any data are most welcome – thanks for your help
    Above kit was manufactured by Mine Safety Appliances Co., Braddock Ave. & Thomas Blvd., Pittsburgh, Pa., U.S.A., the kit is referred to as M-S-A FIRST AID KIT, 12 UNIT – TYPE D (unfortunately there’s no mention of any date)
    Please email me with any comments mailto:[email protected] David Steinert © Copyright 2001
    Tom
    littletommy and Lyterx like this.
    Apr 2014
    Dryden NY
    6,342
    You appear to have a 12 unit "D" model. Vehicle mounted during WW1 by the US military.
    Tom
    May 2014
    Yooper, MI
    1,510
    I stand corrected.
    Mar 2016
    545
    cc1.jpgcc2.jpgI sent an email to Dave in the above post, Thanks Tom
    It appears the kit I have is quite a bit larger and may be of some interest to Dave Steinert in finding the different types available,
    I also read that some cases had Morphine in them, Guess I should look while Im looking for any other ID to properly date the first aid kit,
    Guess you never know what will turn up at the local Flea.
    Thanks all !
    I hope I can help Dave in his quest in writing these articles.
    Peter B
    Apr 2014
    Dryden NY
    6,342
    cc1.jpgcc2.jpgI send an email to Dave in the above post, Thanks Tom
    Thanks all !
    Peter B
    Well they also made the 16 unit kit in the same configuration. Maybe even a 20 unit but I found no documentation to support that hypothesis.
    Tom
  1. Military veterans face ultimatum - Pills or Pot.
    By littletommy in forum Off-Topic
    Last Post: 05-20-2016, 02:36 PM
  2. Replies: 3
    Last Post: 07-01-2015, 04:34 PM
  3. military bike? 2wd
    Last Post: 02-03-2014, 06:15 AM
  4. Harley Davidson MT350 Military Enduro
    By TW-Brian in forum Off-Topic
    Last Post: 11-09-2013, 09:13 AM
  5. More Military wreckage U.S. Navy TBF Avenger
    By yamamont in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-21-2011, 02:52 PM
