Blown away
Results 1 to 4 of 4
Like Tree12Likes
  • 8 Post By williamemack
  • 1 Post By Fred
  • 2 Post By Kasky
  • 1 Post By elime
Thread: Blown away
    Senior Member williamemack's Avatar
    Apr 2013
    winters in Sudbury, MA, summer on Squam Lake, NH
    363
    Blown away
    I had a posting on CL for a brush clearing saw and offered to throw a second saw in for an additional $75. I hadn't touched this tool for over 15 years. I was stored horizontally on some angle brackets in my unheated barn and all gassed up (two stroke). Well, as the day came when the customer was to arrive (after an endure he was in) I got that baby down, washed her off. Dumped the old gas/oil mix (when I opened the gas cap, I expected just dust to come out)and said OK I'll give it 10 pulls. On the 9th it fired right up like it had been run yesterday . Could have been that I last refueled before ethanol and my stabilizer was good stuff.
    Oh yes, buyer bought both saws.
    I sell TW200 stickers for $2.00ea. delivered. See Hidden Content for details. Hidden Content
    2014 TW, DMO pegs, Yamaha rack, Doubletake mirrors, Jimbo shield, extended pilot screw, Snapback clock, Ebay risers, Seat Concepts, o-ring chain, Ricochet skidplate, brake leash, IMS folding shift lever, ProCycle tool tube, 130 main jet and two shims, route sheet holder, compass, temp/humidity
    indicator.
    18,727
    Impressive reliability. Not much to go wrong with older two-stroke engines or carbs though. Reed valve petals can warp a bit but the carbs are darn simple. Hydrophilic ethanol can promote cylinder wall pitting but perhaps the pre-mix oil leaves a protective barrier.
    Smitty Blackstone likes this.
    Senior Member Kasky's Avatar
    May 2016
    118
    2 stroke carbs do store better. 4 stroke fuel bowl is vented to the atmosphere. 2 stroke diaphragm is atmosphere on one side and fuel on the other. Fuel caps allow air to be drawn into the tank as fuel is used but are not open to atmosphere and dont leak when operated in various positions. I dont worry about my 2 stroke tools during the winter but drain the bowls and flush with seafoam on the 4 stroke stuff.
    6,976
    I'm impressed. After 15 years and it starts right up -- that usually doesn't happen that way.
    littletommy likes this.
  1. 2013 with 3500 miles blown engine.
    By Kosovo101 in forum Technical Help
    Last Post: 09-01-2014, 06:56 PM
  2. blown engine gasket
    By canyonlock in forum Technical Help
    Last Post: 06-03-2014, 05:52 AM
  3. Steering wobble and blown clutch
    By 5chord in forum Technical Help
    Last Post: 09-27-2013, 09:19 PM
  4. Blown up engine
    By Guitarman in forum Technical Help
    Last Post: 09-19-2013, 04:53 AM
