Garage Fires
Results 1 to 9 of 9
Like Tree19Likes
  • 11 Post By Fred
  • 1 Post By Moabman
  • 2 Post By Rider21
  • 1 Post By williamemack
  • 1 Post By 1911garand
  • 1 Post By Fred
  • 1 Post By arbolmano
  • 1 Post By jtstdub
Thread: Garage Fires
    18,721
    Garage Fires
    Local fellow I bought my trailer from just had one of his storage buildings burn down loosing his tractor, a matching set of his and hers ATVs, a couple snowblowers, etc.
    I asked him if he had any BatteryTenders operating. Indeed he had two charging both the tractor and one ATV, both with wet cell batteries. He indicated that his son, a motorcycle mechanic by trade, said that several fires have been attributed to BatteryTenders or other charging devices left on for too long.
    With all the diesel and gasoline involved the fire's heat was sufficient to melt aluminum. As such the fire investigators said they doubted enough evidence existed to indicate a probable cause.
    However a word to the wise is to perhaps not trust many devices to be left drawing current unattended for extended periods of time.
    Senior Member Moabman's Avatar
    Mar 2014
    UTAH
    260
    Thanks for the insight, Fred
    jtomelliott49 likes this.
    Senior Member Rider21's Avatar
    Aug 2015
    Reno, NV.
    430
    Thanks for sharing that Fred. I have 3 going all the time. Maybe I should start cycling them.
    jtomelliott49 and mhomadness like this.
    Beauty is as beauty does.
    If it works good, it's beautiful.
    Senior Member williamemack's Avatar
    Apr 2013
    winters in Sudbury, MA, summer on Squam Lake, NH
    363
    I've always been a little leery of these devices so I make a 2.25 hr trip to NH in the wintertime to charge up the batteries. Yeah, I know it can be done with a smart phone, but I don't have one and can't get my wife to get one and learn how to use it.
    I sell TW200 stickers for $2.00ea. delivered. See Hidden Content for details. Hidden Content
    2014 TW, DMO pegs, Yamaha rack, Doubletake mirrors, Jimbo shield, extended pilot screw, Snapback clock, Ebay risers, Seat Concepts, o-ring chain, Ricochet skidplate, brake leash, IMS folding shift lever, ProCycle tool tube, 130 main jet and two shims, route sheet holder, compass, temp/humidity
    indicator.
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    715
    Battery tenders are good, but not needed 100% of the time in the off season.
    In the off season (dead of winter), I remove the batteries from the summer toys and bring them inside to utility room. Then charge them once a month with a tender, good to go. No need for a tender to be plugged in for 5 months!
    To each their own though - lots of opinions on battery storage. (like engine oil)
    Good Luck!
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    18,721
    I am not really attempting to say bad things about BatteryTenders per se. They were unlikely responsible for the mentioned fire, but they are certainly possible candidates. More it is an advisory about concern about risks from overheating batteries during the charge, or float cycles. Not all electronic stuff should be trusted to work fault free. I had a rather pricey peak charge detecting charger for R/C Ni-Cad that worked flawlessly until one day it decided to become a Suzy Baker Oven and attempt to incinerate a battery pack. Had I not been present to see battery pack smoldering I could have had a house fire.
    Senior Member arbolmano's Avatar
    Feb 2012
    Arroyo Grande, Ca
    782
    One has to pay attention. I had a cheap trickle charger that decided it wanted to go big. Took out a new wet cell unit by overcharging and flooded my shop with hydrogen gas, a byproduct of charging. Go around sometime an check those little transformers used for cell phone, notebooks and the like.
    amazing how hot they get. One more minor detail..........good job Fred!
    Tonto on the "Left Coast"
    1987 TW200 (2) 2015 BMW F700GS
    More Wagging and less Barking
    "Enjoy yourself, it's later than you think"
    Make Love not War
    Jan 2015
    Fair Oaks, Calif
    500
    Been using small Battery tenders for over 20 years... Usually at any time I have 3+ plugged in and taking care of batteries. Mowers, Cycles, cars..
    Not enough current to boil a battery... 500ma.
    My battery power tools chargers, that's another story. I unplug them when not in use... They are built well and probably would not flame up but I do not like things that do not need constant power to operate left plugged in!
    I will conclude with one last statement....
    If I were a law maker I would demand that most electronic devices be 100% turned off when not in use!... TV's, Microwave's etc...
    Ask, how can you do that?
    The only reason most devices need power is for the clock and remote turn on to keep folks from having to get off their ass to turn things on.
    All that is needed is for the clocks and Ir receiver to run on batteries... Circuit to turn on the incoming power.
    Technology has been around for a long time that learn and remember channel settings etc when power is removed from the devices...
    Even Cell phone chargers do not need constant power.
    Oh well we know this will not happen...
    Just like no new dams for water, no new nuke power plants but lets conserve and let the population grow....
    Jim
    Fred likes this.
    Sep 2012
    Wichita, KS
    1,868
    Thanks Fred. I use a battery tender jr. My garage is heated, and motorcycles are inside, so batteries stay in bikes. Mower stays outside under carport, so battery comes out to be stored on shelf in garage charged. I do, however, have a problem with my black and decker cordless drill. I think my charger fries it's batteries. lol,,,,no, not lol, not funny. I think I'll buy a DeWalt next time.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
  1. 3 kicks and she fires up!
    By JoeH in forum General Discussion
    Last Post: 04-18-2016, 11:28 AM
  2. Washington fires
    By rbm in forum Off-Topic
    Last Post: 06-29-2015, 09:12 PM
  3. fires and evacuations
    By joeband in forum Off-Topic
    Last Post: 05-15-2014, 07:35 AM
  4. Danskin OHV Closed for 2014 due to 2013 Fires
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-20-2014, 07:43 PM
  5. The Garage Thread
    By Point37 in forum General Discussion
    Last Post: 11-21-2012, 04:03 PM
