Never Change the Oil?
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree90Likes
Thread: Never Change the Oil?
    May 2013
    Groton, NY
    2,663
    A friend of the family wanted me to service her push mower for her. Sure, I can do that. I'll change the oil and sharpen the blade, clean the air filter, and it will be all set for next spring. Couldn't find a drain plug, so I looked up the manual online and it says, "no oil changes needed for life"!? Here is a LINK, see for yourself. It must not last long with that philosophy!
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member CS1983's Avatar
    Aug 2011
    Tulsa, OK
    634
    Still have to add.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,388
    it's probably the same as today's appliances. they last 10 years and then go for recycle
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Member ViolatingLlama's Avatar
    Oct 2016
    Boise, ID
    60
    I would argue you could do that with any lawn mower. I'd say you could do that for quite some time before any apparent consequence. But most mechanically inclined people know the truth- you don't not change the oil in any engine. Old becomes contaminated with blowback from combustion, as well as metal filings from both engine break in and normal wear and tear.
    If you've ever seen oil coming out of propane fueled vehicles during an oil change, it's pretty darn clean. There's still blowback and metal contaminants, but not carbon from combustion (or at least not much of it). Doesn't mean it all shouldn't be changed.
    The only thing special about the Briggs & Stratton EXi series is that Briggs & Stratton sells the engine as special.
    Design an engine where the oil is contained in the oil filter after shutdown and by changing the filter you change the oil, and turn in the filter to a recycling center. That I might buy.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,048
    I would be forced to stuff a suction hose down the fill tube and suction the old oil out before adding all new oil. Oil is cheap compared to engines. This mower IMO is a throw away when something does break. I have a Troybilt rototiller with a B&S engine that is around 38 years old. It runs like a charm after I rebuild the simple carb ever few years and change the oil often. Starts on one pull every year and is just a great engine.
    1987 Yamaha BW350 Big Wheel
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,482
    Use it till the warranty expires then it blows up and you buy a new one. Wow what a great concept.
    Oct 2014
    Armstrong BC
    2,388
    I've fooled around with a lot of b&s in lawn tractors over the last 10 years and from what I've seen is that most people don't even check the oil, let alone change it. I think briggs knows that and knows the owner will blow it up because there is no oil in it and that will be the life of the motor. I've rescued a few lawn tractors that have been kicked to the curb because the rod was hanging out the side of the engine
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Nov 2010
    Frostbite Falls Ill
    2,719
    Yep, oil is good for the life of the engine. The life of the engine is over when it seizes up or throws a rod because of dirty or low oil.
    These engines probably do not have rod or wrist pin bearings at all. Maybe not even main bearings. Just metal to metal until they wear out.
    They are not rebuildable, the factory probably does not even sell parts. Just a throw away product.
    Phelonius
    Sep 2012
    Wichita, KS
    1,868
    I have a Walmart push mower with a Honda engine. Same thing, no drain plug. I tip it up on its wheels with the fill cap off to drain oil, then re fill. What Phelonius said. Life of the mower is when it seizes up or just quits working.
    Funny though, my dad didn't worry about dirty oil as long as it had viscosity. Glad I didn't carry that tradition on.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,775
    Quote Originally Posted by grewen View Post
    I was talking to a Sears salesman about this fact. He said Briggs did a study and found most owners do little or nothing to maintain their products and the no oil changes ever was a good selling point. Makes me wonder how long it will be until auto manufactures get on the idea.
  1. First oil change in my 'new' '99
    By wolfy in forum Technical Help
    Last Post: 06-06-2016, 09:07 PM
  2. Oil change
    By osheen23 in forum Technical Help
    Last Post: 04-24-2016, 10:23 AM
  3. Oil Change:
    By Justncase in forum Technical Help
    Last Post: 05-09-2015, 06:34 AM
  4. Oil Change.
    By ZDR1 in forum Off-Topic
    Last Post: 04-12-2015, 05:25 PM
  5. Oil change D'oh!
    By joeband in forum Technical Help
    Last Post: 09-30-2013, 10:04 PM
