Yamaha BW80 headlight?
Results 1 to 10 of 11
    Aug 2011
    Cayce, SC
    3,109
    I'm trying to figure out a good way to run a headlight on my little big wheel. Any suggestions?
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Jul 2011
    1,123
    Don't know anything about them to be of much help, but can always ask questions to lead in the right direction...
    Any idea what the electrical output is or what kind of power generation setup it has? Does it have a battery? How much light do you need/want? Maybe an LED setup like ronnydog put on his would work? Certainly lower power requirements than a traditional headlight.
    Looking at how minimalistic it is, you might not even have a way to power a headlight. Not sure they would go to the trouble, given the lack of any electrical devices that would require power. It would probably be relatively easy to adapt a stator lighting coil from another bike if that is the case. You can then either run headlight directly (will dim at low rpm and not work unless engine is running) or add a rectifier and battery if there is room for a small one.
    Lots of options if you have to go totally custom (depending on how much work you want to put in) but someone here probably knows the drill.
    Best of luck!
    ITCB
    Aug 2011
    Cayce, SC
    3,109
    Hmmm... there is no battery(kick starts). I'm not very knowledgable about these little 2stroke bikes. Everything i've learned has been from taking it apart and putting it back together. Maybe a light with a battery pack in or attached to it? Headlamp? Not trying to spend too much on it considering I only paid $500 for the bike, but I also want it to look decent. Just need enough light to putt around the yard at night after work.
    Maybe the electric company can put up a streetlight or two?
    866
    Build a baseball field in your yard. Then add a few jumps. Watch out for the rookie.
    Senior Member yoter's Avatar
    Apr 2011
    112
    catch fireflys in a mason jar.
    sorry, had to say it.
    id get one of those big square flashlights and mount it.
    with duck tape
    Aug 2011
    Cayce, SC
    3,109
    Lol. Will do yoter. Im looking around for any kind of decently bright led light that I can velcro, 3mtape or wrap around the fairing. I dont need want to deal with connecting it to the engine or trying to. Large headlamp may just do the trick but I was hoping you guys would have some ideas... other than fireflies! Lol Gonna go look around pep boys this weekend
    866
    Quote Originally Posted by JdubSC View Post
    You might take a look at some of the bicycle lights available. They've got some high zoot ones, depending on how much you want to spend. I've got one that I spent about $50 on and it works perfectly for nighttime mountain bike trail riding. I'll try it on the tdub if I get a chance.
    http://www.biketiresdirect.com/searc...powered-lights
    http://www.biketiresdirect.com/searc...rgeable-lights
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    We are required to have headlights and taillights on all our dirtbikes here so I have had some experience adding lights to bikes that don't come with lights. If the bike doesn't have a battery, the issue becomes more difficult. The stator is general only wound for ignition on a bike that's not equiped with a headlight. If there is a stock headlight, the stator has additional windings on the "lighting" coils and usually a battery. Most headlights run directly off the stator and the taillight/signal lights run off the battery. I don't konw any company that rewinds the BW80 stator - you could contact Baha Designs or Ricky Stator.
    I think your best option is a LED light for a bicycle like this:
    Strykr LED
    Regards...Wes
    918
    Sold bike.
  1. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 01:32 AM
  2. BW80 handlebar swap
    By PalmStateCrawler in forum Off-Topic
    Last Post: 09-05-2012, 11:39 PM
  3. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
  4. Rim Swap or Different size tire for BW80
    Last Post: 06-11-2012, 07:09 PM
  5. Where to get Yamaha logo decal for headlight shroud?
    By darnold87 in forum Performance and Customization
    Last Post: 11-06-2010, 09:53 AM
bw 80 upgrades
bw80 jump youtube
bw80 motor swap
bw80 performance
can a head light be installed on yamaha 80cc
headlight for yamaha bw 80
lighting coil for yamaha bw80
yamaha 110 headlight
yamaha big wheel 80
yamaha bw80
yamaha bw80 forum
