carb advice 2002 WR250f
Results 1 to 3 of 3
    Senior Member yamamont's Avatar
    Sep 2011
    North of Seattle
    172
    So I got a 2002 WR250f with at least 3000 miles that I put on myself. Before I got it it had barely been ridden.
    So, it has a JD main jet #128 ( I think) and the needle for my elevation installed.
    Yeah, it needs a valve adjust and cam chain, however once warm she runs as good as ever.
    ever since the JD kit install Gas drips out as I kickstart it, float bowl out of adjustment? Yes, the plug has been black due to running way rich.
    I adjusted the float the other day the best I could as directed by my factory repair manuel.
    Gas still dripped out, yet more.
    So I plan to go back in deeper for cleaning and inspection.
    I dont have calipers for the float adjustment as directed by the manual. (nor do I have budget for them right now)
    So I used a 8mm wrench and a keen eye. (didnt turn out to keen)
    So what else should I watch for when I am in there?
    Any sweet tricks to getting the float bowl set just right.
    I hope to get my cam chain and tensioner soon for install followed by valve adjust. depends on budget.
    it really runs great and starts easy...once warmed up.
    918
    Check your float needle and seat, too.
    Double-check your float height with a piece of clear tubing.
    Trial and error is the name of the game for float height. You can make a gauge block to help with a consistent measurement, but it's critical to rest the float at just the right spot against the needle. If not, each measurement will be different and you'll be chasing your tail.
    Sold bike.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,389
    Quote Originally Posted by Yamamont View Post
    While checking the float needle seat, check the condition of the o-ring.
    If it is dried out and flattened, fuel can pass around the seat even if the needle valve is fully closed, and cause the bowl to overflow.
    Old seat on right, new on left:
    jb
  1. Need Advice - Electrical, Carb, Brakes...help
    By Lonesome Dave in forum Technical Help
    Last Post: 03-26-2013, 09:14 PM
  2. 2002 tw200
    By twdave in forum TW200 Classifieds
    Last Post: 03-14-2013, 03:17 PM
  3. 2002 TW200
    By SeawardAction in forum TW200 Classifieds
    Last Post: 09-06-2012, 07:46 AM
  4. FS: 2002 TW200
    By neve_r_est in forum TW200 Classifieds
    Last Post: 07-06-2011, 07:09 AM
  5. Carb Soaking Advice Wanted
    By lorddaftbiker in forum Technical Help
    Last Post: 06-23-2011, 11:18 AM
2002 wr250f carburetor
2002 wrf250 carb tune
2002 yamaha 250wr carb
2002 yamaha wr 250 carb
2002 yamaha wr250f float sticks
how to adjust carb on 2002 wr 250
how to clean carb on 2002 yz250f
how to clean carb wr250f
what is factory settings wr250 carb
wr 250 carburetor removal
wr250f yz250f needle
yamaha carburetor adjustment wr250
