Missing head gasket?
Results 1 to 3 of 3
    Aug 2011
    Cayce, SC
    3,109
    I have been completely restoring my bw80 and when I pulled the head I noticed there is no head gasket! I have not pulled the cylinder yet but I see that it does have the base gasket. I know there is supposed to be a head gasket on there but it has been running since I bought it without one. Is there anything wrong with not running a head gasket? I am about to order one, But just curious, does it effect performance? I am new to 2strokes and have been taking it apart cleaning/inspecting and reassembling to learn more about them.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Desert, SoCal
    7,369
    Running without one would increase the compression ratio. No way it would be worth the risk of potential sealing problems or predetonation.
    Aug 2011
    Cayce, SC
    3,109
    Thanks LB. I was thinking maybe the p.o. didn't put one on to raise compression instead of milling the head. Strangely enough I found an unused one in the box of spare parts. This lead me to believe he may have simply forgotten to put it on working in a hurry. After cleaning out the ports and muffler i'm putting it back together now. It's a real pain to get the rings compressed to re-install the piston. It got late so I will try the zip-tie method tomorrow.
  1. what tool am i missing?
    By dutchbat in forum Technical Help
    Last Post: 06-02-2013, 12:28 PM
  2. That !$%/* head gasket leak keeps worsening!
    By Guitarman in forum Technical Help
    Last Post: 06-06-2012, 07:20 PM
  3. Head gasket leaking oil?
    By Udoug in forum Technical Help
    Last Post: 10-25-2011, 01:01 AM
  4. Replies: 3
    Last Post: 08-15-2011, 07:43 AM
  5. Missing bolts?
    Last Post: 09-06-2010, 02:19 PM
head gasket
yamaha bw80 cylinder gasket installation
