Tires
Results 1 to 9 of 9
Like Tree18Likes
  • 7 Post By plumbstraight
  • 2 Post By Fred
  • 2 Post By Gruff54
  • 1 Post By Blueduce
  • 5 Post By Fred
  • 1 Post By Fred
Thread: Tires
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,674
    Tires
    What a pain. Some of you know that I have a 5500 dodge truck I do my traveling with to haul the nessities and trailer with. Well I ordered a set of rears for it. The price is all over the place from the 140's to over 250 a tire. I ordered a set on line and took them to the local auto dealer for get them changed out.
    Not an issue with the tireman, but holyxxxt, what a pain to take them off the truck. ten lugnuts, no problem, now to get the wheels off the hub, NO WAY!!! I took it home with the lug nuts loose hoping they would let go,,NOT. I wound up hooking my tractor to them with a chain and yanking first the top then rotating and jerking them again. Got the outside wheels off, put three nuts back on after breaking the inside wheels loose somewhat and left them less than finger tight hoping they would break free a bit better in the mile back to the tire shop. Had two on the bed and was lucky enough to beat the inners off when jacked up. Those wheels are machined fit to the axle. Took 4hrs to get them all fixxed up. I hope to get another 84000 mi out of these because I hope the next time is a ways off.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,468
    I have worked on a new F250 and had to heat the rim cherry red to get it off. North American vehicles are a joke.
    18,407
    Imagine if you had had a flat in the back of beyond some where! Not everywhere will help come along like if you were on the Dalton Highway.
    Any preventative steps to take? I am becoming a fan of this:antisieze.jpeg
    Smitty Blackstone and troll like this.
    Junior Member Gruff54's Avatar
    Apr 2018
    Central NC
    29
    X2
    Mike
    Senior Member Blueduce's Avatar
    Sep 2014
    Central valley Ca.
    209
    Fred; I to am a fan of anti-seize, but NOT the copper compound, the copper reacts poorly w/ sea water and can cause an electrolysis nightmare.
    I had it smeared on my props (mercury) spline shaft for one season and had to literally CUT the prop off. Marine mechanics won’t let it in there shops.
    All things being equil, opt for the pure graphite compound. Hell,.. I shoulda just smeared some of my waterproof axel bearing grease on the damn thing...
    Smitty Blackstone likes this.
    "Cycles is a mean toy lady" Halsy Knox
    2,674
    The issue is that the hub to wheel is a machine fit. The lugnuts are flat, not tapered so the hub itself takes the load not the lugnuts. When I put them back on they had to be cinched down by the nuts. If I did get a flat it would have to stay that way until I got to a place to take them off. Antiseize will not help much in this situation.
    Sep 2014
    Mamaroneck, NY
    2,173
    X3
    Love that Copper stuff!!!!
    Quote Originally Posted by Gruff54 View Post
    X2
    Mike
    18,407
    Thanks for the tips. Copper, silver, nickel, moly, aluminum...so many anti-seize options. Maybe I should just go with the food grade, might be good for constipation.food.jpeg
    TW-Brian, admiral, Mel and 2 others like this.
    18,407
    Did initially understand plumb's machined mating surfaces issue.
    Just thought a bit of anti-seize might make disassembly easier in the future.
    After a slew of recent tire & brake issues including some pounding on parts that should have separated cleanly I tend to now reach for the anti-seize.
    Other issues I have seen in last 6 months were four cases of a lack of the proper tools, jack, or security key preventing an easy tire change, including my new truck I am ashamed to say.
    plumbstraight likes this.
  1. Tires/Replacement Tires for a 2007 xt225
    By stagewex in forum Technical Help
    Last Post: 09-15-2018, 07:55 AM
  2. tires, tires..
    By bozofs in forum Performance and Customization
    Last Post: 08-20-2012, 08:25 PM
  3. Tires
    By sakogu in forum Performance and Customization
    Last Post: 09-30-2010, 03:30 AM
  4. Old Tires
    By Petrus in forum Off-Topic
    Last Post: 09-15-2010, 01:21 AM
  5. ATV Tires - Everything You Need to Know
    By vuldub in forum Sticky threads
    Last Post: 08-16-2010, 09:13 AM
