99 4Runner Steering Wheel Reinstallation...!???
Results 1 to 8 of 8
Like Tree5Likes
  • 1 Post By Badgerflorida
  • 1 Post By jeepster09
  • 2 Post By littletommy
  • 1 Post By kj7687
Thread: 99 4Runner Steering Wheel Reinstallation...!???
    Senior Member kj7687's Avatar
    2,438
    Question 99 4Runner Steering Wheel Reinstallation...!???
    Please excuse the rant below I find myself easily losing patience these days. The first paragraph below is mainly background and ranting/raving. After that is my question. Thanks in advance.
    I took the steering wheel off of my 99 Toyota 4Runner -- following the instructions in the manual -- in order to remove my ignition switch. It turns out the *** **** ****** ******* manual was completely wrong, and I wasted my time and effort removing the steering wheel. In reality, there is absolutely no reason to remove it; it is COMPLETELY unrelated to the ignition switch. I followed the manual ASSUMING the ******* manual would not just randomly tell me to do a bunch of shit I didn't need to ******* do. I was wrong to make that assumption. My god I am getting SO TIRED of these Haynes manuals: they are GARBAGE not worth the paper they are printed on! I've found SO MANY things misleading or flat out wrong in more than one of these damn Haynes manuals; I HATE them! This is literally a five minute job; I could've saved myself all of this hassel by using my brain and looking around in there instead of following the idiot book. There are literally two screws securing the ignition switch to the back of the key lock cylinder; you remove the screws and pull it out and unplug it -- THAT'S IT! Following the instructions in the manual, I removed the air bag/horn assembly, steering wheel, and dash panel assembly -- absolutely NONE of which is AT ALL necessary to replace the ignition switch. The screws are easily accessible and easy to remove without removing ANY of that crap! Yea I know, I should've looked more closely at the actual switch assembly BEFORE following the manual...but I didn't.
    ANYWAYS...I actually didn't come here to rant about that. I need some advice regarding the steering wheel itself.
    I had to use a steering wheel puller tool to remove the steering wheel after removing the steering shaft nut the first time. I pulled on the steering wheel HARD (after initially removing the nut that secures it in place) and it wouldn't budge the first time, but came off pretty straightforwardly using the puller tool (with a notable POP sound, as one gets when pulling suspension parts...). Anyway, all the WONDERFUL....manual....says to do is tighten the steering shaft nut to 26 foot pounds (I've verified the torque spec elsewhere...). I did that but suspected that wouldn't press the steering wheel hub back onto the shaft. So after I torqued the nut to 26 foot pounds, I removed it again and tried pulling on the wheel; sure enough, the steering wheel popped right off.
    I tried hammering on the steering wheel hub with a socket to get it to press back onto the shaft, but that did nothing.
    Am I missing something here...? This is an interference-fit that needs to be pressed back on and then should be tight and shouldn't just easily pull off by hand....RIGHT? What's the problem? What am I doing wrong? I could just put some blue loctite on there and torque the nut and call it good, but this just doesn't seem right. Or is it...? If the steering wheel IS all the way back on, why didn't it require any force to get it all the way back in, if a puller was required to remove it from that position the first time around? And why is a puller not at all required to remove it now!?
    Any advice on this?
    Edit: here are a couple of posts that I looked up before making this question post (one has pictures for reference as to what I'm talking about):
    https://www.yotatech.com/forums/f2/s...4runner-89437/
    https://community.cartalk.com/t/why-...einstall/80516
    KJ, just KJ, ok.
    Current rides:
    Jun 2017
    Milwaukee, WI
    1,328
    I use this guys 4Runner videos for a lot of my Tacoma maintenance. He’s using the factory manual and only a torque wrench. Pretty sure he is or was a Toyota Technician.
    kj7687 likes this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    2,438
    Badgerflorida, thank you for the response and the video. I went ahead and just put blue loctite on it and torqued it to 26 foot pounds. It sketches me the hell out though, if I'm honest. It just doesn't sit right with me: I don't understand how it can require a puller to remove (with a "pop" sound as the tension was released, just like in the video) and then just be able to slip right off again after torquing the nut to spec and then removing the nut again...
    I guess maybe because the splines "freeze" in place over time...? I don't know man. I'm so pissed that I removed this thing for absolutely no damn good reason. Stupid useless service manual!
    At the end of the day, I guess I at least have two things stopping the steering wheel from coming off in my hands...: the nut torqued to spec, and then the loctite as a backup/fail-safe. Ugh. What else can I do, I guess...sigh.
    Hopefully this at least fixes the occasional failure-to-crank problem; I already replaced the starter motor/solenoid assembly.
    KJ, just KJ, ok.
    Current rides:
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    You are overthinking it. As long as you have the splines properly engaged and the nut torqued down it isn't going anywhere.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    306
    You did fine. A couple of tips for future. Use factory manuals in case you didn't, the aftermarket manuals are mostly a joke and to generic. NEVER use a hammer to drive wheel back on; many have a "collapsible column", pounding with hammer will shear nylon collapsible pins.
    GOF likes this.
    "Life Member NRA"
    2,438
    I'm definitely not pleased with this situation. Either it's done wrong or it's done right and I just don't understand how it works (probably the latter...). Either way... Anyway, thanks guys.
    KJ, just KJ, ok.
    Current rides:
    Thankful for all of my friends!!
    17,625
    I wouldn't worry about it KJ. It's pretty normal for something to break loose with a pop under pressure and then go back on like yours did. As long as you have a full nut or more on the threads and it seems to be bottomed out it should be just fine. You can't tighten it any further, right?
    jeepster09 and kj7687 like this.
    1st John 1:9
    John 3:16
    John 3:17
    2,438
    It is definitely a nut-depth on and torqued to spec. And I have driven it around since without any drama, LOL... Thank you.
    littletommy likes this.
    KJ, just KJ, ok.
    Current rides:
