2015 Honda pcx 150.
Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By frog13
  • 2 Post By Leisure Time Larry
Thread: 2015 Honda pcx 150.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    2015 Honda pcx 150.
    Picked up one of these scooters on the 5th , nice machine . The owners manual specs the engine and final drive / tranny fluid as Honda HP4M 10w 30 . Problem is , Honda dealers around here do not carry the 10w 30 only the 10w40. Same JASO spec.of MB , just different final weight number . This 10w 40 MB should be ok for this unit....Ya think?. I joined the PCX forum. The riders there say the MB (molly) isn't really important , but , the Honda engineers spec'd it , so I'd think it is beneficial .
    docjekyll2002 likes this.
    Senior Member toma55's Avatar
    Aug 2014
    NE Illinois
    166
    I'd like to know your impressions after you have had tie to evaluate the PCX.
    Jul 2012
    Wet-ern Washington
    1,409
    Quote Originally Posted by frog13 View Post
    Times, they are a changin'. Modern engineering and manufacturing to tighter tolerances call for different lubrication recommendations from the manufacturers than the "old standards". There is a little too much "that'll do" attitude around for my liking. It happens a lot on forums, but I especially despise it when it comes to dealers. Yeah, 10W-40 has been a very common oil weight for bikes, but my 2013 Honda CB500 also calls for 10W-30, so I get where you are coming from. Dealers don't stock it, and they will tell you what they do stock will be fine. Or worse yet, you take your machine in for service to see on the invoice that they put in 10W-40 when your manual clearly calls for 10W-30, and they say it's no big deal, when really it is because all they use is from the big drum back there, and because doing what is right would be an inconvenience for them.
    Really? The 40 wt. properties will act exactly the same at higher temperatures as the 30 wt. in that brand new machine? Hmm, what about the 10W-50? At what point does it start to matter oh-all-knowing-dealer-guy? Maybe we should call the oil companies and let them know that they are wasting their time and money by making these distinctions and formulations. They should just put "OIL" on all of the bottles and let's be done with it! Fyi, this is a new problem with cars too. A lot of new cars are coming with a 5W-20 recommendation, but your local X-Lube place probably doesn't have a drum of that.
    Anyway, buy a couple changes worth online like I do, and then tell the dealer that you bought it cheaper online because they're pigheaded. And, don't let others make you feel like an ass because you want what the manufacturer wants you to put in it.
    Check out this video where ericthecarguy speaks with representatives at Valvoline. The whole thing is a good watch, but @ 6:12-12:16 they speak to this issue of viscosity. Or, if you are super short on time, start at 9:36.
    kj7687 and frog13 like this.
    - Leisure Time Larry -
    Jun 2011
    SW, Ohio
    2,518
    Only 150 Miles so far on the pcx , but it runs quite well for not being broke in. MPG is fantastic so far , again ,not broke in yet....it will improve on its current 94 mpg , running between 40 & 50 mph , per the riders on the pcx forum .
    THE big issue with the pcx forum , is that there are a lot of folks who are in the camp of , " any synthetic oil will do fine". I do not agree with this mentality.
    The pcx is incredibly smooth and quiet. I'll post more as time goes on and if the approaching Ohio winter permits .
    Aug 2014
    NE Illinois
    166
    Please do. I need a new scoot. Selling the 650 Burgman. Need something at 250 or less. The 125 Zuma is cute and fun but scary even at 50 with such a short wheelbase. The PCX has larger wheels, I believe, and seems longer. Probably more stable. Nice cargo hold under the seat too.
    Jun 2011
    SW, Ohio
    2,518
    I contacted Honda corporate in Torrence Cali. Regarding the lack of final drive lubrication info in the owners manual . Result , a free service manual !.
    Also , strangely , the engine and the final drive use the same fluid...HP4M 10W 30 MB (moly spec'd oil) .
    I called again to confirm the 10w 30 MB oil for both units , you can use the 10w 40 version for the engine , BUT , the rep was adamant 10w 30 to be used in the final drive . I'm new to scooters , but Honda spec'd a moly (M oil for a reason. The service Dept. At my local Honda , said to use either Honda's 80w 90 weight gear oil OR Honda's HP4....which is garden variety 4 stroke oil. The rep about crapped his self when I advised him of their recommendations . Go figure .
  1. 2015 Honda Adv Bike.
    By ZDR1 in forum Other Bikes
    Last Post: 10-07-2014, 08:14 AM
  2. 2015 dl650xt
    Last Post: 09-30-2014, 08:19 PM
  3. 2015 ktm rc 390!
    By kj7687 in forum Other Bikes
    Last Post: 09-03-2014, 10:12 PM
  4. 2015 tw
    By Mkfchef in forum General Discussion
    Last Post: 08-25-2014, 06:28 PM
  5. What do you think of the 2015 TW200?
    By dgclassic in forum General Discussion
    Last Post: 06-25-2014, 04:54 AM
2014 pcx 150 gear oil volume
2015 honda pcx 150 forum
gear oil capacity for honda pcx
honda pcx 150 forum
oil for honda pcx 150
pcx 150 forum
pcx 150 gear oil change
pcx 150 transmission oil change
pcx forum
what oil to use in a 2015 honda pcx
what synthetic oil to use in a 2015 honda pcx
what type of gear oil is used for pcx150
